Jaguar Mk 2 brake servo
Old Dec 2, 2024 | 06:21 AM
Lodron's Avatar
Default Jaguar Mk 2 brake servo
I am looking for a new/reconditioned Jaguar Mk 2 brake servo. These are pricey from Jaguar specialists, but I suspect that the same servo is fitted to other vehicles (eg Land Rovers), and would be much cheaper. Can anyone advise? Thanks, Ian.
Old Dec 2, 2024 | 07:07 AM
Bill Mac's Avatar
If you are not really stuck on originality, I suggest look at other brake boosters.
The PBR VH40 is a great replacement. In Australia they run from A$200 to A$600.
It is typically only the fraction of the price quoted for an original booster rebuild.
If you sniff around, you may be able to dig up a similar replacement in the European area.
Old Dec 2, 2024 | 07:42 AM
hueyhoolihan's Avatar
i purchased one recently, they can be had for 300 to 500 U.S. at the usual parts outlets for jags, although it's not really a jaguar OEM part.. it's probably a reproduction. a used one, if it can be found, would be about half of that. i think i bought mine here...
https://www.sngbarratt.com/English(U...rnedDown=false
Old Dec 2, 2024 | 10:51 AM
Lodron's Avatar
Thank you for the above pointers. The SNG Barratt offering is still over £200, whereas typical Land Rover ones are around £60 and look remarkably similar.
Old Dec 2, 2024 | 12:34 PM
Peter3442's Avatar
I think the boost ratio of the original servo was 3:1. The alternative offered by SNG and others is more like 4:1. A lot of the less expensive remote servos have a boost ratio around 2:1. Since the standard Mk2 brakes, though they work well, require a strong push, a 2:1 servo might not be very comfortable to use.
Old Dec 3, 2024 | 06:49 PM
Bill Mac's Avatar
Disc brakes require higher pressure than drum brakes
I suspect the Land Rover booster would be for drum brakes and not suitable for disc brakes.
MK1 3.4 s with drum brakes used the same booster as the disc braked cars including MK2s however they were fitted with a restriction valve/port to slow the onset of otherwise harsh braking.
GGJag
Nov 15, 2024 10:27 AM
Agnes Radin
22
Feb 27, 2023 01:13 AM
MussieRon
Mar 31, 2022 04:23 PM
Yellow series3
May 18, 2020 11:38 AM
nascardad88
Aug 5, 2014 06:32 PM
