Jaguar Mk2 heater controls
Old Mar 27, 2024 | 05:37 AM
Glyn M Ruck's Avatar
I used to think that the S Type's vacuum operated system was a negative. On reflection, as long as you have a good water valve, it seems a positive. Mine works like a charm. The only negative is you are using hot air to demist which is slow. Modern vehicles use AC cold air to demist which happens very quickly.
Old Mar 27, 2024 | 07:32 AM
Lodron's Avatar
My heater flap is not spring loaded. It must be set and held in the desired position.
Old Mar 27, 2024 | 07:34 AM
Yes. I think Peter was suggesting a spring might help in that case. I'm an S Type man and don't know all the differences to the Mk2. I use Lin's blog for Mk2 queries.
Old Mar 27, 2024 | 07:38 AM
https://valvechatter.com/?p=2116
Old Mar 27, 2024 | 07:43 AM
A very useful resource for Mk2 owners.
Old Mar 27, 2024 | 10:27 AM
Rishi's Avatar
Thanks, I have been looking for something like this!
Fantastic content from Lin. I hope he leaves it up.
Old Mar 27, 2024 | 11:09 AM
He intends leaving it active.
Old Mar 27, 2024 | 11:59 AM
  #28
Peter3442's Avatar
Lin's valvechatter is classic. Landieman is also very helpful:
https://landieman.com/
For the spring, I think, but I'm not certain, there should be one present, but it's not very strong and rusts away. Generally, apart from not having the capacity to deliver large volumes of very hot air, the heater works so long as it's regularly used with a warmed up engine. A period without use, especially in a humid environment, and the flap seals stick or fall off, the hinges rust solid, and the whole device deteriorates.
Old Mar 27, 2024 | 03:30 PM
Just get used to using the site. Some have difficulty.
Jag Mk2
Go to " Restoration Blog"
> Then to all the drop down menues
> Then where applicable sub drop down menues
Good luck!
Old Mar 27, 2024 | 06:14 PM
  #30
Improved/consolidated to 1 post.
TSTYLZE
Jun 4, 2025 08:25 AM
oldole
Dec 19, 2022 06:44 AM
Eric-in-Texas
Jun 3, 2021 05:02 PM
rb9421
Mark V - X 420G
Feb 13, 2021 08:31 AM
Simon.h
May 7, 2012 11:41 AM
