Mark 2 Steel Wheel offset Distance
Old Mar 17, 2023 | 09:00 PM
oxendine's Avatar
Default Mark 2 Steel Wheel offset Distance
What is the offset on a steel wheel? The back spacing seems to be 4" but not sure of the offset.
Old Mar 17, 2023 | 09:46 PM
Peter3442's Avatar
With 5" rims and 4" back space, the offset (or inset) should be around 30mm. I think most Jaguars from the late 1950s through to X308 had that sort of offset as standard with steel and alloy wheels. Some wire wheels may have a reduced offset to give a wider track.
I think offset = back space - flange width - rim/2
Old Mar 21, 2023 | 05:44 PM
primaz's Avatar
FYI, you can go to most quality tire/wheel or performance shops and they should have the tool to measure your car's offset options. Even when you do not modify you car as much as I did, you often can get a wider wheel/tire if you measure and get a custom offset wheel which are also available in stock popular styles like the Dunlop racing styles that used in Jag racing days.....
davidmaria1
Jan 9, 2023 12:45 PM
nilanium
Jul 12, 2019 06:44 PM
Tork Monster
General Tech Help
Oct 17, 2018 07:51 PM
gboy
Aug 7, 2015 01:28 AM
Robert Scott Neilly
Apr 25, 2011 01:28 PM
