Mk 2 1963 3.4 Fuel pump mounting
Old May 20, 2020 | 06:01 AM
Superstox's Avatar
Default Mk 2 1963 3.4 Fuel pump mounting
Hi can any one help me I want to fit new mounting grommets (cbc1448) to a new fuel pump the old spacers are very crushed does any one know how long they should be?
Old May 20, 2020 | 04:05 PM
JeffR1's Avatar
They should be about level with the new grommets, or just slightly below.
This is so because when the pump is mounted, you want the spacers to take the load when the nuts are tightened up.
This allows the new grommets to take the weight of the pump with out being crushed and to absorb the sound of the pump.
Old May 21, 2020 | 06:32 PM
Glyn M Ruck's Avatar
See here: Fuel System ? Valve Chatter
Scroll down.
Old May 21, 2020 | 06:53 PM
JeffR1's Avatar
I would use rubber grease for the grommets, not Vaseline and boiling water.
Old May 21, 2020 | 06:57 PM
Vaseline is just fine. It is just microfine wax & totally rubber compatible.
Old May 21, 2020 | 11:42 PM
JeffR1's Avatar
I found rubber grease to be more slippery.
Makes dealing with difficult rubber products that much easier.
Old May 22, 2020 | 06:50 AM
Yes ~ depends what you are doing. e.g. Vaseline/Petrolatum is the preferred product for rubber seals (elastomers) used on Auto transmission valvebody assemblies (e.g. Allison)
tedwone
Aug 26, 2019 02:39 PM
romroc
Nov 14, 2017 10:01 AM
trguy75
E type ( XK-E )
Apr 28, 2016 09:27 PM
plums
General Tech Help
Jan 17, 2016 02:28 AM
gunnerman
XJ40 ( XJ81 )
Jun 24, 2010 08:55 AM
