MK II Side Marker Lamp
Old Jun 19, 2021 | 06:08 AM
RMerkley's Avatar
Default MK II Side Marker Lamp
I am repairing the side light markers on the front fenders. The main wire keeps pulling through the insulating “washers. Any suggestions on how to stiffen, Replace or modify to prevent this?
Ray
Old Jun 19, 2021 | 11:00 AM
Jose's Avatar
does it only come out of the socket when the bulb is pressed against the wire contact?
if yes, then the issue must be caused by the insulating washer not preventing the contact from being forced backwards by the bulb contact, if that makes any sense.
the solution is to replace the insulating washer with a nylon plastic washer, cutting it the same as the insulating washer so to slide it over the red wire. In the US you can find small nylon washers in ACE Hardware or Lowe's in the Specialty Hardware section.
Old Jun 19, 2021 | 03:31 PM
JeffR1's Avatar
Or just get a new set, looks like it needs replacing anyway, the lens should be clear, not yellow.
Old Jun 19, 2021 | 04:26 PM
Fraser Mitchell's Avatar
Like this one: -
https://www.sngbarratt.com/English/#...20Id%202005859)
Old Jun 19, 2021 | 06:54 PM
JeffR1's Avatar
Yup, they're pretty common.
Old Jun 22, 2021 | 07:28 PM
RMerkley's Avatar
Thanks for the advice/comments. I think for now I will try Jose’s suggestion and put it on the list of things I may replace down the road based on budget priorities.
310jag
Feb 25, 2019 08:22 PM
MrJagSwag
XK120 XK140 XK150
Sep 1, 2018 09:15 AM
hlgeorge
May 3, 2017 06:51 AM
toyman
Mar 30, 2017 01:36 PM
mkontos
Dec 24, 2014 02:48 PM
