Mk2 / Daimler V8 LHD gear control linkage (auto)
Old Jan 20, 2014 | 12:10 PM
ceejep76's Avatar
Default Mk2 / Daimler V8 LHD gear control linkage (auto)
Hi,
I'm in the process of converting my car from RHD to LHD.
(1963 Daimler 2.5 V8).
Does anyone have pictures of the gear linkage below the
steering wheel on a LHD automatic car?
Any help appreciated. There is minor differences between LHD
and RHD. I would probably have to make minor changes to the
brackets or fabricate new ones unless I can find the parts:
For the gear linkage (LHD auto BW35)
Gear linkage (I have no picture of this):
- C21130 Abutment bracket and clamp assembly for (gearbox) housing)
- C20933 Transfer lever and bracket assembly for operation of the gear control cable
( or - C22210 Transfer lever and bracket for later cars, have to check my chassis no. + C22282 stiffening plate )
- C20947 Link from operating shaft to transfer lever
I am also looking for a few other parts:
Handbrake:
- Handbrake lever bracket: Part no C15502 which is for the whole assembly with the lever. I do only need the bracket for the LHD car though as the lever is similar. See attachment, the bracket is highlighted in yellow, the ears for the bolts go the other way though.
- C8991 Housing for handbrake shaft (where the handbrake shaft goes through the tunnel)
Throttle pedal:
- C28077 which is the accelerator pedal (there are 3 different types used on the MK2 LHD)
Brake pedal:
-Brake pedal for automatic car (only the pedal without levers or the brake box)
Regards
Jan-Erik Pihl
Bergen, Norway
barrymk2
Jan 1, 2015 04:49 AM
patpin
Sep 16, 2014 04:09 PM
DjiXas
Jan 2, 2013 07:00 AM
Stu 1986
Nov 29, 2012 09:33 AM
