Mk2 Handbrake
Hi Guys
The fun continues with the 3.8 Mk2, the handbrake stuck on whilst out the other day, had to get brought home on a flat bed. On inspection the handbrake is of the self adjusting type and didn't seem to be sticking as much as it felt when driving, has anyone any links as to how these work? I can guess the principle, but I want to strip them and don't want springs or clips jumping out when I take them apart.
Hi Guys The fun continues with the 3.8 Mk2, the handbrake stuck on whilst out the other day, had to get brought home on a flat bed. On inspection the handbrake is of the self adjusting type and didn't seem to be sticking as much as it felt when driving, has anyone any links as to how these work? I can guess the principle, but I want to strip them and don't want springs or clips jumping out when I take them apart. Thanks Graham
One tip I have is from my rebuild of 1981-87. The handbrake has a central compensator post bolted to the diff, from whence cables go to each individual caliper on each wheel. This post has lovely phosphor-bronze bushes but no means of lubrication. I took a nut which had the same thread as a grease nipple, welded it onto the post, drilled a hole through to make a passage, then screwed in a grease nipple, so I could keep this lubed up and eliminate seizure. I also rebuilt each individual handbrake caliper too.
You can still get the individual handbrake caliper wearing parts, here is a supplier.
SNG Barratt - UK | Parts
Thanks for that I'll check the compensator as well, I took the self adjusting mechanism apart on the passenger side and it had collapsed internally due to a broken pin retaining a spring.
graham
graham
Pluckie
Oct 3, 2015 07:57 AM
RollaJones
Sep 27, 2015 03:31 PM
1964Daimler
Sep 9, 2015 11:28 AM
