Screw Sizes
Old Oct 13, 2021 | 10:35 AM
Robot's Avatar
Question Screw Sizes
I know that screws/bolts above 1/4" are UNF or to a lesser extent UNC
What are the smaller screw sizes?
Are they UNF, Whitworth, or BA ?
Old Oct 13, 2021 | 10:52 AM
Jagboi64's Avatar
Generally UNF. About the only place you find BA threads are on the Dunlop brakes and SU fuel parts (carbs, pump). The timing chain adjuster nut on the engine is also BA (7/16")
Old Oct 13, 2021 | 02:11 PM
Fraser Mitchell's Avatar
You should not find any Whitworth/BSF threads on the car. Almost all will be UNF with UNC where the thread is in an aluminium casting. As said, BA is common on the small sizes, particularly the electrical stuff. BA is a pseudo-metric standard almost always used for electrical components in all places.
You can read all about it here: -
https://en.wikipedia.org/wiki/Britis...nd%20modelling.
The only real way to know what a bolt is, is to measure it with a caliper gauge to determine diameter, (a ruler is no good), plus a thread gauge.
Old Oct 21, 2021 | 08:15 PM
Bill Mac's Avatar
MK1 & Mk2 Jaguars are full of UNF nuts and bolts.
I keep a hundred UNF10-32 nuts on hand as I replace old rusty nuts when I am doing any work. In the last couple of days I have removed and replaced front door handles held on by 10-32 nuts and also a MK2 front grille ,also held on by 10-32.
I also keep a hundred 8-32 nuts on hand for the occasional smaller ones that I encounter.
If you have any difficulty locating these nuts try aviation sources as American aircraft are full of UNF/UNC threads.
Bill Mac
MK1
MK2
S3XJ6
X300
15 previous Jags MK5 to X308
Rsee
E type ( XK-E )
Aug 26, 2020 07:15 AM
Willyb
Jun 11, 2015 08:26 AM
JaguarKnight
Oct 30, 2010 09:02 AM
cegibbs3
Oct 15, 2008 06:58 PM
