Starter motor problem
Old Aug 29, 2025 | 01:48 PM
Pussy's Avatar
Default Starter motor problem
Have a starter motor problem the flywheel has 104 teeth the starter has 10 teeth and the gearbox is a all syncro with overdrive my problem is the starter has had some modifications to get it to work there seems to be a miss match of something someone has elongated the hole so as the starter can move away from the ring gear and work I’ve put a standard starter without the elongated hole and it jams on the flywheel is there a miss match I’ve bought the car that was stripped and it’s all together this is the issue I’ve had it running with this starter but it’s not right
Old Aug 29, 2025 | 01:52 PM
Pussy's Avatar
Old Aug 30, 2025 | 07:34 AM
Homersimpson's Avatar
It might be worth speaking with these guys: https://www.powerlite-units.com/starters/rac300.html
Your engine looks like one from a later XJ6 which probably explains the mismatch, the one Powerlite list for the 4.2 engine only has 9 teeth whereas the MK2 version has 10 https://www.autosparks.co.uk/powerli...-starter-motor
Old Aug 30, 2025 | 08:10 AM
Pussy's Avatar
When the 3.8 was in there we had the same problem
Old Aug 30, 2025 | 09:36 AM
Is your car manual or auto as the auto starter motor is different to the one you have?
Old Aug 30, 2025 | 09:46 AM
Pussy's Avatar
In the first thread it tells you it’s a full syhcro with overdrive manual with with 10 tooth starter which is manual
Old Aug 31, 2025 | 01:58 PM
Bob_S's Avatar
I have not had the problem but others have had problems when they mix 3.8 and 4.2 bell housing/starters and flywheels. You must use either the bell housing/flywheel/starter from a 4.2 or the bell housing/flywheel/starter from a 3.8.
it sound like you have a mixed bag of parts and they tried to fix it by slotting one of the starter bolt holes.
cheers
Bob_S
Abbas_ahmd
Apr 3, 2023 01:27 PM
pampurd
Mar 3, 2014 08:55 PM
shoeymac
Jan 22, 2014 09:33 PM
Sparty
Sep 20, 2011 09:34 AM
rivs
Nov 13, 2007 05:55 AM
