gperna
Old Mar 29, 2012 | 01:42 PM
gperna's Avatar
Default gperna
My wife’s 2002 X type 3.0 Jag has what we describe as a "frog" problem when she applies the Brake the car stops but the ABS frog goes on. There is no ABS or yellow engine light but some times while driving they go on but go off once restart car. I checked the Code and get P1000 and C1175 I know what these codes mean. I put all New Brakes all around about 4 Months ago without this problem showing up Then. At that time there was a C1165 problem, which I replaced the right rear sensor which solved that problem and got clear codes. (Past inspection) So I am discounting Brakes. before that time the ABS frog did not work at all. I believe the two problems are related but different. I am trying to understand the difference. My first idea is to change the left rear sensor but I think the problem is in the ring on the shaft (Or what ever they call it) becomes the ABS still works (to Much)
Any insight would be helpful.
Old Mar 29, 2012 | 04:42 PM
Welcome to the forum ,
Head on over to the X tech section and you will get a better response.
Old Mar 30, 2012 | 06:50 AM
The Chris X's Avatar
Welcome to the forum - I'm not sure about frogs, but to me it sounds like you probably have a reluctor ring missing a few teeth. Common problem. Search/post up over on the X-Type forum and I bet you'll find some good info. I know I had to replace my rings several times on my 02 X.
Best of luck!
Old Mar 30, 2012 | 04:28 PM
gperna's Avatar
Thanks for the welcome and advice Now only need to navagate to that sight
Thanks again
gperna
2002 X-type 3.0
Old Apr 1, 2012 | 08:31 PM
Hi there, welcome to Jaguarforums, good to have you here with us
If you get stuck or have issues with the site, please just ask..........
If you add your car details to your signature it will help others to help you much more quickly.
In the meantime I've manually upgraded you to full forum access so you can better view the whole site and all its features.
so jump on in and enjoy
Hope you enjoy your time here!!
Old Apr 2, 2012 | 07:14 AM
Thanks again
gperna
2002 X-type 3.0
Here's the X-Type Forum
X-Type - Jaguar Forums - Jaguar Enthusiasts Forum
General Tech forum:
General Tech Help - Jaguar Forums - Jaguar Enthusiasts Forum
gperna
Apr 6, 2012 11:08 AM
