Help me please X type drama
Hi guys and ladies.
I need some help I have 2002 2.1v6 X type. I had to replace the right front abs sensor as I had the codes read from jaguar. anyway that was a week ago now for some reason there is a loud sqweeling noise coming from the right front wheel when I drive about 10 KS and a score ring around the disk like something is stuck in there. weird thing is that the abs light is coming back on again but when the wheel sqweels the abs light doesn't come on but the brakes vibrate but when the abs light does come on the sqweel noise isn't there. does anyone have any ideas? thanks. |
Welcome to the forum Alex,
Good to have you with us at Jaguar forums. That sounds like a sticking brake caliper and/or worn out pads, Follow this link https://www.jaguarforums.com/forum/x-type-x400-14/ to the X-Type forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues. Please remember to add vehicle details to your Signature to help others to give relevant advice. Go to the User CP button on the left of the top menu bar, then Settings & Options under Your Control Panel. Select Edit Signature and enter the details. If my geography is correct, you can also visit the Australia - Western Region forum by following this link https://www.jaguarforums.com/forum/a...ia-western-96/ to find other members in your region. Enjoy the forums. Graham |
Best to remove the road wheel and inspect the work that was done to see if it was performed correctly.
Hello, Alex,
Welcome to the forums from ElinorB. (';') |
Welcome aboard Alex.
Welcome.
Not good, so time for closer inspection, and self sorting. Good luck. |
Welcome to the forums.
Welcome to Jaguar Forums Alex,
Good to have you with us. Enjoy the forum. If you haven't done so already you should add your car details to your signature to help others to help you. If you need help with getting around and using the forum follow this link for some help Forum Help |
Originally Posted by GGG
(Post 1910656)
Good to have you with us at Jaguar forums. That sounds like a sticking brake caliper and/or worn out pads, Follow this link https://www.jaguarforums.com/forum/x-type-x400-14/ to the X-Type forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues. Please remember to add vehicle details to your Signature to help others to give relevant advice. Go to the User CP button on the left of the top menu bar, then Settings & Options under Your Control Panel. Select Edit Signature and enter the details. If my geography is correct, you can also visit the Australia - Western Region forum by following this link https://www.jaguarforums.com/forum/a...ia-western-96/ to find other members in your region. Enjoy the forums. Graham it's weird as only makes the noise when warm |
Don't forget braking generates a lot of heat and as caliper housings/pistons heat up they expand. If something is going to stick, it's more likely to stick when it's hot.
It's not unusual to feel pulsing through the brake pedal when braking hard. This is the ABS working to prevent lockup. However, excessive vibration on one wheel only could be symptoms of a worn hub bearing. Graham |
Originally Posted by Alex Ashmead
(Post 1910633)
Hi guys and ladies.
I need some help I have 2002 2.1v6 X type. I had to replace the right front abs sensor as I had the codes read from jaguar. anyway that was a week ago now for some reason there is a loud sqweeling noise coming from the right front wheel when I drive about 10 KS and a score ring around the disk like something is stuck in there. weird thing is that the abs light is coming back on again but when the wheel sqweels the abs light doesn't come on but the brakes vibrate but when the abs light does come on the sqweel noise isn't there. does anyone have any ideas? thanks. the noise was indeed a loose brake pad so thanks for that. the abs sensor problem is still there I less the brake and it vibrates then the abs light is coming on that obviously makes my cruise control not work. do you think this is a faulty abs pump? thanks. |
It could well be a fault with the ABS module. Have a look at the ABS/Traction Control section in this FAQ thread:
https://www.jaguarforums.com/forum/x...ts-data-29800/ There's links to threads with details on troubleshooting and repairing. Graham |
