str running lean
Old Jul 14, 2012 | 08:55 PM
walt83's Avatar
Default str running lean
hi im walt83 in new to this so hi all who read this. but any i have a 03 jag str 4.2 about a week a go i got the restriced performance and code p0171 and p0174 and bank 1 and 2 are lean. so i replace bank 1and 2 o2 sensor before cat. and still same code so the next day i replaced the ones after still same problem can and body help!!! p.s. alco have codes p1646 and p1647 ,p1111
Old Jul 14, 2012 | 09:45 PM
QuartzSTypeR's Avatar
The running lean is likely due to a vacuum leak of some sort. Check out the S-Type sub-section (probably where this thread will be towed to shortly) of this forum and search and you will come up with some spots to check.
Old Jul 15, 2012 | 04:07 AM
Welcome to the forum Walt,
Sorry to hear about the restricted performance issue. Before throwing more parts on, follow this link S-Type / S type R Supercharged V8 - Jaguar Forums - Jaguar Enthusiasts Forum to post this tech question in S-Type section. Resident experts there should be able to troubleshoot the DTC's for you.
Old Jul 15, 2012 | 08:48 AM
Follow Grahams advice. The original codes were most likely an air leak the sensors were just showing the fault. You need to check that you have fitted the correct sensors and all the connections are good.
Old Jul 15, 2012 | 07:49 PM
Hi Walt and welcome to the forum, good to have you here with us
This is the new members section and you're unlikely to get the best help here. Please check into the relevant section for your vehicle for the best help on offer............
I have manually upgraded you to full forum access so you can better view the whole site and all its features
Old Aug 13, 2012 | 10:45 PM
Daled78596's Avatar
I have a "restricted performance" alarm and stopped into the local dealership. Told me I had a cracked plastic air intake valve and it was causing a lean mix. $125 to tell me that, and $485 to order the plastic intake valve and install it. Did I just get duped? (First time on the forum and this is the only place "search" led me)
Old Jan 6, 2013 | 05:01 PM
walt83's Avatar
Finally took my jag to the dealer they say its a blown head gasket leaking into my valves and. That took out my o2 sensers and mas air flow. For the total job its going to cost 6500. Those this sound right to anyone
clubairth1
30
Sep 3, 2025 04:38 PM
tbird6
Aug 13, 2024 07:50 PM
WinterJag
16
Oct 9, 2015 07:49 PM
OkieTim
Sep 8, 2015 04:48 PM
OkieTim
Sep 2, 2015 12:48 PM
