Changing my thermostat this weekend.....
Old Apr 1, 2009 | 04:07 PM
phd12volt's Avatar
Default Changing my thermostat this weekend.....
ok so i need to replace my thermostat this weekend, and it shows that it is a 2.7 hour job. My local shop quoted me 410 dollars to install it. Soooooooooo since im not paying 400 dollars for someone to swap out my thermostat, and i can bleed the system myself, i looked arounf under the hood and it looks like it is 3 torx screws (t-30 i think by looking at it) and it seems i have the aluminum housing already. Is there some sort of issue that makes this a 2 and a half hour job for some reason???
And for some odd reason the local shop said it is 95 dollars for the thermostat??? seriously do these people think im that stupid? ughhhhhhhhhhhh sry had to vent a little
Old Apr 1, 2009 | 10:52 PM
03JagSTR's Avatar
I replaced my thermostat with a low temp thermostat from Eurotoys.
http://eurotoysltd.com/catalog/produ...oducts_id=1173
I completed the job in about half an hour.
Old Apr 2, 2009 | 06:29 AM
Brutal's Avatar
And for some odd reason the local shop said it is 95 dollars for the thermostat??? Seriously do these people think im that stupid? Ughhhhhhhhhhhh sry had to vent a little
yes that works both ways...love it when something like a belt change time stays the same even though now you have to take all kinds of stuff out of the way even see the belt..and yes parts prices are going through the roof,,i do have a 6 cylinder t stat new though...$25 shipped pm me
Old Apr 3, 2009 | 12:12 AM
phd12volt's Avatar
i have the thermostat already, looks like the bottom t-30 torx is the only one that might be iffy to get to. Also, the overflow tank on top of the motor, is there another opening to the radiator itself??? i looked quickly today but didnt see it right off the bat. Is there another one under it???
Old Apr 3, 2009 | 12:14 AM
phd12volt's Avatar
honestly i can see this being the case at the dealer...........but i am talking about a local shop.......so they want 410 labor +95 dollars for a thermostat???? I cant see the dealer charging me that much
Old Apr 3, 2009 | 11:11 AM
hottienamedscottie's Avatar
That's ridiculous. I thought I paid too much when my shop charged $300 for labor and $30 for the Thermostat on my STR.
Old Apr 3, 2009 | 12:38 PM
Brutal's Avatar
no thats it. and 300 for a t stat on a R, thats ridiculus too, the R's are easier to change than the normally aspirated. Its right up top and easy to change...sometimes I think people think cause you have a Jag you got money to burn....Parts are already high enough without being gouged on labor thats out of line
Old Apr 3, 2009 | 03:38 PM
phd12volt's Avatar
Thanks for everyones insight and help........i did the themostat today and all is good. It required a flathead screwdriver to remove the air intake piece. 1 out of 10 for being difficult(10 being very difficult), opened the resoviour first, released the pressure. Removed 3 bolts surrounding the themostat housing, which was aluminum on my car. Required a t-30 torx bit on a 1/4 drive ratchet, with a 6 inch extension. Stuff a ****load of rags on top of the belts, wiggle the housing side off let it spill onto the rags. moved it up and pushed it back. Pry out old themostat carefully from the mount. WHOLE CRAP LOAD OF coolant will spill. Hence why i used so many towels/rags. Have the new thermostat ready to go with the o-ring installed. Install new thermostat the way the old one was. If you do it quick enouogh, you will lose minimal fluid. Install housing back on. Screw the t-30 torx back in. Remove soaked rags/towels. Reinstall air intake. leave the cover off the overflow for now. I filled up the overflow about halfway, and started the car and let it run. While it was running, i went in the house and grabbed my scanner so i could monitor the coolant temperature. Got to about 203° before i heard the engines fan kick. Watched the overflow to make sure i could see bubbles and hopefully it wouldnt start backing up and spraying everywhere. All was good. Reinstalled the overflow cap and went for a spin, i finally didnt hear the high speed fan running anymore, and i monitered the temp the whole time. Seemed to stay right at 205° and then running the a/c it was at 210° the whole time.
Brutal, is this what it should be?
Old Apr 3, 2009 | 03:42 PM
phd12volt's Avatar
Ohhhhh and parts were as follows_
Thermostat from Pep Boys= 13.99
Prestone Orange long Life Antifreeze=14.99 for 1 gallon
40 minutes of my time due to the fact i was cleaning the motor off under the covers.
Old Apr 3, 2009 | 04:41 PM
phaelax's Avatar
Dealership replaced my thermostat and waterpump last summer. Pump was covered, thermostat was not and the part and labor cost me $550. Then again, this is the same dealership that took over 2 hours last month to replace 2 plugs and coils. They were also kind enough to give me an estimate on replacing my pads and rotors for me for only $1400....
Old Apr 3, 2009 | 08:45 PM
Brutal's Avatar
sounds about right, the fans should only come on high when too hot, or when ac head pressure is too high. Otherwise low speed only, except for Xtypes, they regulate ac pressures with the fan indtead of the clutch
Old Apr 6, 2009 | 12:22 PM
Hmmm...I see you are in Ohio, but your description of the dealership you went to sounds impeccably close to that of Monte Shelton Jaguar in Portland, OR....crooked and money hungry.
As far as pads and rotors go...you should look into Brake Performance's website and talk to a guy named Andy. He's been helpful, and I think I'll be getting better quality products for less money than the overpriced Brembo crap the dealers tell you to buy.
Old Apr 6, 2009 | 02:06 PM
H20boy's Avatar
What, and no pictures? I'm feeling a little disappointed...such a good writeup too.
Old Jun 18, 2009 | 01:16 AM
bankerkys's Avatar
Excellent write-up. Thanks! I will attack mine on Saturday.
Old Jun 18, 2009 | 08:37 AM
Enthusiast's Avatar
I love it when people do a proper write up. Good job!
Old Aug 13, 2016 | 06:35 AM
phb's Avatar
phb
Thanks for this post. I bought a 2006 Jag S-Type this week which I drove from Florida to Michigan. Trip went well. But the next day, the cooling sign showed up. From reading your post, I am wondering whether I should try to change the thermostat or the water pump or both. If so, I might need some guidance. Can you advise, please?
Old Aug 13, 2016 | 07:35 AM
bydand's Avatar
A little light on detail.
find out where the (relatively small) leak is coming from and fix that.
look for dried out coolant crust, and see if it weeps (wet) after a drive when upto temperature.
Have a look at the dccv (duel climate control valve) as one of many things. expansion tank etc etc, which could be leaking, or you will be changing out a lot of stuff for no good reason.
Sounds like a great drive with the Jaguar thou, How many miles on this trip.
Old Aug 13, 2016 | 08:30 AM
phb's Avatar
phb
Thank you, bydand. It was about 1500 miles. A great ride indeed.
There is no sign that coolant is being lost. Since I am a first time Jag owner, I cannot differenciate between sounds that would be normal and abnormal Jag sounds; but the fan seems to run high. The engin heats up fast, even when I start the car in the garage and let it run idle. Would that be enough detail to warrant changing the thermostat first and then try to change the water pump if the first does not solve the problem? Thank you very much for your advice.
Old Aug 13, 2016 | 08:37 AM
phb's Avatar
phb
Thank you, phd12volt, for this post. I am communicating with bydand (who also contributed to this thread). And I would also like to get your opinion, please. I purchased a 2006 S-Type Jag this week. It overheating icon is showing on the dash. There is not sign of leak. Would you advise that I changed the thermostat or the water pump or both? If so, would you give some advice and guidance from your own experience? Thank you!
Old Aug 13, 2016 | 09:09 AM
Jon89's Avatar
phb,
Forum member phd12volt is long-gone from here. He sold his car a number of years ago....
