Front Marker Lamp Removal
Old Mar 27, 2010 | 05:39 PM
ashmorem's Avatar
Default Front Marker Lamp Removal
Please can anyone help with what should be a fairly simple task?
I need to change a bulb on a front marker lamp on an '06. Do I need to remove belly panel / air close out to get access from underneath? Or is the housing removable from the outside without access to the rear? I don't want to force anything and risk braking the tabs that probaby secure the lamp.
Old Mar 28, 2010 | 09:05 AM
cacloss's Avatar
It's fairly easy to remove/replace that bulb. The instructions from my Owners Manual are as follows:
Remove the light unit by pressing the lens downwards to compress the spring clips. Gently ease the top of the lens from the bumper and remove the complete unit. Twist the bulb holder anti-clockwise and remove the holder and bulb from the lens. Fit a new bulb of the correct type, W5W. Refit the bulb holder, complete with bulb, to the lens unit. Press the unit into the recess until it clicks into place.
Old Mar 28, 2010 | 06:12 PM
Bull27's Avatar
I am assuming you are talking about the piece cacloss explained how to replace, but if you are talking about the side marker, it has a clip on one end, you get your fingernail underthere, depress it and it will pop right out. I had to remove them when i changed them from Amber color to smoked.
Old Mar 29, 2010 | 07:01 PM
ashmorem's Avatar
Default Front Marker removal
Thanks for the comments. I had already checked out the manual. Even following the removel directions the lamp is stuck fast. I do not want to force it and may revert to removing belly panel to see if I can reach up behind the lamp. Thanks again.
Marc
Old Oct 17, 2010 | 01:51 PM
carelm's Avatar
Marc
I wound up using a flat tip screwdriver to press the marker lens down from the body. It popped out OK, but agreed the manual's description is not as easy as it looks. I found the lamps from AdvanceAutoParts for $5.00 per pair. They are Sylvania 2825.
I had an interesting Saturday though. I took my S-Type into the dealer for a required emissions inspection expecting to pay about $40 or so. When I went to the cashier, they said no charge as they were running a clinic that day. Also, they had donuts available. They did try to make it up by saying I needed a new air filter and a side marker. Total parts and labor $170. I politely declined and got a new filter for $17.10 and a new lamp for the above mentioned $5.00.
It helps to do your own labor and investigation. My guess is that they think the typical Jaguar owner doesn't like to get his/her hands dirty and will pay dearly for the convenience.
Mike
Old Oct 17, 2010 | 02:23 PM
aholbro1's Avatar
Ooh! You coulda had 10 of them for that at Rock Auto....
http://www.rockauto.com/catalog/moreinfo.php?pk=319053
Here's a few pics of the left-rear I swapped on a MY-03 S-type, maybe it helps to see what you are dealing with. As is evident...the spring clips will break. FWIW, installation is a breeze, so when you get it out, you are WAY over 1/2 done
Attached Thumbnails Front Marker Lamp Removal-img_20101017_141450.jpg   Front Marker Lamp Removal-img_20101017_141420.jpg
dsnyder586
Dec 29, 2024 07:39 PM
Daim
Nov 28, 2016 09:28 AM
XCrossWindsX
Sep 5, 2015 10:58 PM
Dallas XK8
Sep 3, 2015 12:17 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
