"Hazey" Headlamps - A remedy?
Old Aug 1, 2007 | 10:42 AM
tallblondeguy's Avatar
Default "Hazey" Headlamps - A remedy?
Hi guys/gals, a quick question.
Living in Florida, most cars down here tend to develop a fog (or hazey buildup)on the headlamps. Seems to be worse here than other parts of the country. I'm close to the coast here, and I've been told that it's the brine(salt) in our air combined with the always-bright sun and sand on the road that cause it to be worse here.
Anyway,....anyone know of a good system to remove the haze? I bought one of those hand-buff (wax-on wax-off) kits at the autoparts store, but it was crap (but it DID work great for removing bugs from the front bumper!)
Suggestions? Anyone with similar experiencethat had success getting off the haze?
Old Aug 1, 2007 | 10:47 AM
badmojo's Avatar
Default RE: "Hazey" Headlamps - A remedy?
I have the same issue with my headlights. It looks like they were sand blasted! I bought some lens polishing compound but haven't really had a chance to use it yet.
Old Aug 1, 2007 | 10:58 AM
Not sure where you are, BadMojo, but maybe it's not just a Florida thing?
Let us know if the compound works for you. I got thisflyer that someone left under
my wipers one day for "Headlight Restoration" , but they charge over $100 bucks, so I'm seeing
if there's another option.
Old Aug 1, 2007 | 11:08 AM
Hey tallblondeguy / Badmojo.........there is a cracking article on the subject ( link posted below )
Ok.......so its from an Audi forum that I'm a member of, but, a headlight is a headlight as far as cleanings concerned, right?
Hope it helps
Jim
http://www.audiworld.com/tech/ext68.shtml
Old Aug 1, 2007 | 11:12 AM
badmojo's Avatar
I live in Chicago and my car was leased in the same area before I bought it. I think it might be due to alot of highway driving by the previous owner. I will let you know how this stuff works. I think the key is that you need to use an orbital type buffer with the compound. Just doing it by hand doesn't work too well.
Old Aug 1, 2007 | 11:18 AM
JimC64, perfect !! I'll try it this weekend or next and let you guys know if it works, or if I screwed up so badly that Ineed new headlamps!
Ifanyone sees me cruising around Ft.Lauderdale with a flashlight tied to my hood ornament, you know for sure that I f***ed up ! lol.
Thanks Jim.
Old Aug 1, 2007 | 11:29 AM
No probs tallblondeguy ( we really need to give you a nickname i think.....your names wayyyyyyyy too long....lol)
Hope it helps and look forward to hearing how you got on.
Jim
Old Aug 1, 2007 | 11:35 AM
ORIGINAL: JimC64
Jim
"TBG"?
Old Aug 1, 2007 | 11:45 AM
PMSL.......Thats exactly what I was thinkin...and what I will be calling you from now on in any posts. TBG it is!!!
I just get Jim or JC
Jim
Old Aug 1, 2007 | 12:01 PM
badmojo's Avatar
Nice detailed article, Thanks! I am a tool maker and can polish a piece of rough steel to look like chrome and have also done some plastic but never a headlight lens.
Old Aug 1, 2007 | 12:04 PM
Np Badmojo
Jim
Old Aug 1, 2007 | 12:09 PM
bigdreams05's Avatar
Well...I'm big or biggie, so he can be tall or tallie!
Old Aug 1, 2007 | 07:31 PM
bmw745ion19s's Avatar
I dont think its just a Florida thing for the haze...some car washes or dealers offer this restoration a lot cheaper... i think ive seen it for about $30 for both before max...ive heard some lenses are coated while others are not...i have some slight haze at the top of two of my lights the dealer said I could easily compound out with a random orbital...hope this helps
Old Aug 2, 2007 | 12:31 PM
secondtonone317's Avatar
some brake fluid on a rag will help........it wont be as clear as new but it well be alot better than what it probably is now
Old Aug 2, 2007 | 01:02 PM
ORIGINAL: secondtonone317
Thanks 2nd2-none, but I tried that one too...didn't work either, ...so I'll try the wet sand method, ...soundslike aton of work, but I don' t see the sense in detailing again until my headlamps look better.
Old Aug 2, 2007 | 01:26 PM
ORIGINAL: bmw745ion19s
Hi BMW745...... I'll look around, but I'm sure I'll end up tryingthe wetsand process myself. Minestarted like yours (just haze at the top)--- then within a yearwas totally hazed over, even the fog-lamps...makes the whole car looklike crap.
Old Aug 2, 2007 | 06:12 PM
no problem, def let us know how it turns out! prayerfully i wont have to worry though...wishful thinking!
Old Aug 3, 2007 | 04:08 AM
momo's Avatar
I don’t recall the name of the product, other that in was in a blue plastic bottle. I purchased it from autozone, it was about $7. It was for a friend, her lights were really yellow/hazy. I used a generous amount of the stuff on each headlight and basically used a lot of elbow grease to scrub off the haze. I repeated the process on each headlight, which took me about ½ an hour. She was surprised when she saw the difference the product made. Remember I did all this by hand no buffer or polisher, just a lot of sweat. I don’t even think that I used half the bottle.
Old Aug 3, 2007 | 10:53 AM
I'll keep you posted on the wet-sanding process. Maybe I should take pics?
Thanks for all the advice !
Old Aug 3, 2007 | 10:54 AM
Hey there TBG.........just a thought.
Before you try the wet sand method, which does a fantastic job, but is a ton of work.
Why not try some good ole fashioned elbow grease with T Cut. If it don't work you have nuthin to lose other than a few $ to buy the product?
Just a thought mate
Jim
