02 jag problem
Old Sep 1, 2017 | 09:20 PM
NotJagFan's Avatar
Default 02 jag problem
hello everyone my father just got a 2002 s type 3.0 (against my better judgement). its having a problem and its a security system i think. It wont start unless you turn the key on and off alot than it will start. I told him key needs replaced and reprogrammed to the right hz. Is that whats wrong or is their something else wrong?
Old Sep 1, 2017 | 09:41 PM
aholbro1's Avatar
Welcome to the forum! Even though you are not a Jag fan (I trust, given your location that you are a Cat Fan, as in BBN....hopefully not a supporter of those Loserville Cards! but I digress) even so not a fan, you'll still need to introduce yourself in the new members area here: https://www.jaguarforums.com/forum/n...-intro-must-5/
and be sure to read the sticky at the top concerning the new member requirements.
Then we can get on with the business of helping your dad get his S-type sorted. I'm personally a bit foggy on the pre-facelift (MY2002 and earlier) models but off the top of my head I believe you've given him bad gouge. Is the PATs light flashing?
Old Sep 2, 2017 | 11:32 AM
Mikey's Avatar
Guessing at cause and solution will cause a person to dislike just about any brand of car.
Does the engine at least turn over when the key is turned to start?
