03 STR crankcase breather hose
Old Jun 19, 2013 | 12:50 PM
RRT's Avatar
RRT
Default 03 STR crankcase breather hose
Folks,
I am trying to find a plastic breather line that runs from the driver side
crankcase and connects to the throttle body from the rear side. Having
trouble at the dealership locating the right part. The sent me the correct
hose that ran from the passenger side crankcase, just having trouble
on the driver side.
The hose is a light plastic and has a connector on each end.
Thanks.
Rob
Old Jun 19, 2013 | 08:00 PM
Michael Star's Avatar
I wish I knew it, but I know that is what was causing a lean condition on my STR
Old Jun 20, 2013 | 08:11 AM
RRT's Avatar
RRT
We just couldn't get the connector at the throttle body to detach. Our local dealer parts guy will hopefully have the correct hose re-ordered and delivered
today.
Old Jun 20, 2013 | 08:18 AM
It was a pain and a half to get it off (esp on the car). I ended up using needle nose vise grips to get it to come off.
Old Jun 20, 2013 | 08:25 AM
GT42R's Avatar
eh im confused,
the PCV from the LH/driver side, goes to the inlet tube, relatively short,
the PCV from the RH/passenger side, goes to the back of the throttlebody, pretty long, goes over the blower,
I managed to crack the one going from RH to throttlebody really good recently when taking everything apart to do the pulley install,
I think it's also causing my occasional P0170/0174 lean code/restricted performance on hot starts...
anyhow, I just ordered a replacement one, hasn't arrived yet, but here's the part number,
AJ8-8039
$33.65
Old Jun 20, 2013 | 11:22 AM
RRT's Avatar
RRT
Thanks, that helps, and please, where is the inlet tube located.
Old Jun 20, 2013 | 11:44 AM
RRT's Avatar
RRT
Oops. Found the location
mikiep
Dec 20, 2019 07:37 PM
NathanDD6
Oct 6, 2015 11:20 AM
inactualis
Oct 2, 2015 11:13 AM
Johncy2000
Oct 2, 2015 01:05 AM
Lubrication
Oct 1, 2015 03:56 AM
