2000-2002 Rear Sub Frame Question
Old May 17, 2013 | 03:37 PM
Six Rotors's Avatar
Default 2000-2002 Rear Sub Frame Question
Has anyone actually switched a Lincoln LS(or T-Bird) rear sub-frame into their S Type?
A friend has a Lincoln LS with a broken bush in the rear subframe---it turns out that the local Ford dealers say their is no replacement bush for the sub frame.
All the Lincoln sub frames from auto recyclers,we have located,have had the frames cut to remove the differential!!!
So the idea is get either a used sub frame of a S Type or a new bush from a jaguar dealer.
Old May 17, 2013 | 04:57 PM
tbird6's Avatar
Considering the LS sold a bunch more than the S Type I think you might have a problem getting one?
Is the sub frame broken or does he just need to change a bushing? If just the bushing he should check with Jaguar if Ford is no longer selling them.
One suggestion: Replace all the sub frame bushings if you take it apart. Not just the one he thinks is bad. It's pretty rare for these to go out? Is there a rust problem?
Many rear sub frames in the US but the cost might be too high with the shipping.
Have you checked EBay yet?
Old May 17, 2013 | 05:24 PM
plums's Avatar
Tijoe is probably the resident JF expert on the subframes.
Rear Carrier Sub-Frame Bushings
Rear End Popping Noise
If the subframes were cut apart, would the remaining bushes not just be considered cheap junk by the yards?
Old May 17, 2013 | 07:46 PM
Six Rotors's Avatar
One bush is broken---the metal which the bolt tightens has fractured and so effectively the sub frame is floating at that corner.
I have located a 2001 S type sub frame for $250 locally.
Or if I knew for sure that a Jaguar bush would fit then the shop(my local Mazda dealer) can press it in to the Ford sub frame.
Old May 17, 2013 | 07:57 PM
Six Rotors's Avatar
Great reference---one of the links describes the exact problem--failure of the metal tube in the centre of the bush.
So as noted above---will a new Jaguar bush fit in the Ford frame?if not will a Jaguar frame bolt up to the Lincoln.
The damaged sub frame has to be returned in order to get the money back.
Old May 19, 2013 | 09:34 AM
Tijoe's Avatar
I am using a 2004 LS subframe for my rear suspension build. LS sub-frames are all the same for all LS's other then when Ford/Lincoln added a mounting plate for an electric parking brake motor. The LS sub frame will only work on 1999.5 to 2003 S-types. 2004 and newer S-types use a subframe that fits the Gen II carrier.
I assume this is what you are looking for?
http://www.ebay.com/itm/Subframe-Mou...068220&vxp=mtr
Old May 20, 2013 | 11:44 AM
Six Rotors's Avatar
More or less---I need the rear bush though.One for sale is for the front of the sub frame.
99xk8guy
Sep 29, 2025 10:51 PM
PMKimpton
Aug 3, 2019 08:22 PM
RaceDiagnostics
Sep 7, 2015 07:28 AM
Joey T
Sep 3, 2015 05:31 PM
Dallas XK8
Sep 3, 2015 12:17 PM
