2000 s type(93k)Engine fail safe mode
Old Jun 25, 2008 | 01:17 PM
mrhayat's Avatar
Default 2000 s type(93k)Engine fail safe mode
Hi,
FJT can you pls advise on this. The last thing I did was got the coil changed as there was a cyl misfire code. I asked my mechanic to clean the throttle body also with some cleaner fluid sprayed on a rag. Now I get this Engine fail safe mode sign after 2 weeks. I havent got the codes pulled yet. But any clues what I could be from past experiences?.
Old Jun 26, 2008 | 07:09 PM
FactoryJaguarTech's Avatar
Default RE: 2000 s type(93k)Engine fail safe mode
Failsafe on stype is normally caused by throttle problem. Could be tps fault or PCM.
Need the codes as always to be of anyhelp.
stanjag
Dec 29, 2024 08:26 PM
MJ'S Jag
Nov 10, 2022 08:14 AM
Fraser Mitchell
Oct 1, 2015 04:06 AM
nelsonht
Aug 30, 2015 06:01 AM
peterg19
Aug 28, 2015 08:42 AM
