2000 S Type Backup Camera Installation
Old Aug 30, 2018 | 04:41 PM
Jaggster's Avatar
Default Voltage from reverse light
LH tail light wiring from electric control module
​​​​​Wiring Color Codes
N Brown
O Orange
B Black
S Slate
W White
L Light
K Pink
U Blue
G Green
P Purple
R Red
Y Yellow
BRD Braid
Originally Posted by RickJ
...in order to connect the backup camera to work only when reverse is selected.
I would say, according the 1999 electric guide:
The seven wires:
3 Black/ yellow = Tail, Fog and Turn grounds
2 Orange/ yellow= Tail/Stop and Reverse/Fog/Turn 12V power
1 Green/ black = Reverse ground (pin 4)
1 Black/ orange = Stop ground
LH reverse light wire is BG (black/green)
RH reverse light wire is BR (black/red)
Parking aid gets juice from WR (white/red) that's connected to the Left Hand side reverse light ground wire BG. This is where I would put the connection.
If you don't need to connect directly to the light connector, consider (LH) Parking aid unit (pin 9) and (RH) Rear electronic control module for connecting. Peel the harness trunk side where you want the connection, if spare tire well is not a good place. Check also Rear electronic control module 17-way connector (ca63) pin 9. You might find both BG and WR wires there since the wiring don't actually change, the schematics do, along accessories.
Rear electronic control module pin arrangement
Old Mar 29, 2019 | 09:37 PM
RedRider48's Avatar
Now, the reduce it!
stanjag
Dec 29, 2024 08:26 PM
MJ'S Jag
Nov 10, 2022 08:14 AM
Lucho Suarez
US Western
Aug 31, 2015 05:23 PM
nelsonht
Aug 30, 2015 06:01 AM
peterg19
Aug 28, 2015 08:42 AM
