2000 S-Type Headlight
Old Jul 7, 2010 | 02:43 PM
Gus's Avatar
Gus
Default 2000 S-Type Headlight
I noticed that my right headlight seemed to have an adjustment problem so I went looking for the problem. What I found is a ball of tape holding the bulb in place the wire spring stay is missing for that light. Not sure if the part is available or if I need to make one. I put the bulb back in and made a bigger ball of tape to hold until I can find a replacement. If a busted up bulb housing is available please let me know. I would be interested in seeing if I can make this one work again.
Old Oct 12, 2010 | 10:01 AM
Gus's Avatar
Gus
Not sure I can help Dave but my first step is to check the fuse for the lights. As for the switch it has a time delay and that is what you might be seeing. This might help http://www.gusglikas.com/images/Auto...01999.25en.pdf diagram 8.1 As for the loose housing you need to check this link https://www.jaguarforums.com/forum/s...ad.php?t=10745 I hope this helps!
Old Oct 12, 2010 | 11:28 AM
Brutal's Avatar
For those with broken too much, i have assemblies. Or if you have halogen and want to upgrade to factory hid assemblies with projectors instead of hid light everywhere kits, i have pairs avail pm me for info. Ill do $250 each till gone. Gus insterested????
puddled
Sep 22, 2015 12:18 PM
OSK_Gomer
Sep 21, 2015 04:33 PM
Super Cat
Sep 9, 2015 03:24 PM
stype40
Sep 9, 2015 08:14 AM
pocketrocket
Sep 3, 2015 07:44 PM
