2003 S-Type V-6 Cylinder Numbering?
Old Feb 18, 2010 | 06:40 AM
Jon89's Avatar
For the 2003-and-newer S-Type 3.0 V6, the cylinders are numbered thusly:
Rear of car
5 6
3 4
1 2
Front of car
You'll have to remove the intake manifold to get to that number 5 coil and spark plug.
Old Feb 18, 2010 | 07:36 AM
joycesjag's Avatar
While the intake is off, replace the IMT O-Rings as well!!! There are a few threads about that subject. Even a FAQ in this section.
Old Feb 18, 2010 | 07:57 AM
Jon89's Avatar
Excellent point. With the intake manifold already off, replacing the two IMT O-rings will take you about five minutes total and should cost you no more than $5 at your Jaguar parts department. I replaced ours a month ago. The original yellow-colored factory-installed O-rings were not thick enough or round enough to provide a long-lasting seal and keep oil from seeping out underneath where the black plastic base of the tuner valves bolt into the metal surface of the intake manifold. Two 8mm bolts for each of the two tuner valves are all that hold the tuner valves in place. The new green-colored O-rings are thicker and rounder and will solve that oil seepage problem. Definitely do this procedure if you're going to pull your intake manifold anyway to get to your number 5 cylinder - it's a no-brainer....
neruda
Oct 18, 2015 01:19 PM
Bcrary3
Sep 11, 2015 10:36 AM
1964Daimler
Sep 9, 2015 11:28 AM
OkieTim
Sep 8, 2015 04:48 PM
KarimPA
Sep 3, 2015 07:32 PM
