2005 Jaguar S Type (V6 Base) rear diff
Old Feb 17, 2011 | 04:09 PM
jordannray's Avatar
Default 2005 Jaguar S Type (V6 Base) rear diff
I have the whine in my rear differential- I tried a fluid exchange- still there with no change.
A mechanic told me that the rear diff was non-rebuild-able, that I would have to get one from a salvage yard or off of ebay-
This does not seem right to me- do they really not make rebuild kits, or sell the parts to rebuild?
I found rebuild kits for other model Jags, but not the S Type.
I can find plenty of jaguar rear diffs on ebay for around the $400 mark, but i'd rather have a rebuilt one with brand new bearings and parts than a used one that could start to whine at any time...
thoughts???
Thanks!
Old Feb 17, 2011 | 04:24 PM
androulakis's Avatar
thoughts???
Thanks!
The BEARINGS are replaceable - you can use Lincoln LS bearings, however the ring and pinion (if that is the source of the whine) is not available. Jaguar sells the unit as a complete diff, and the LS ratios are different (because they never went to a 6spd ZF trans), so that will throw the car into restricted performance.
If you CONFIRM your ring and pinion are fine, then you can use a rebuild kit for a Lincoln LS. There's a lot of info I posted about the difference between the diffs, search I think in the cross reference thread. I'll take a look when I get home.
Take care,
George
Old Feb 17, 2011 | 04:53 PM
jordannray's Avatar
Thanks for that info! Is there a way to determine if the ring and pinion are good without spending a butt load of money having a mechanic break open the case?
Thanks,
Jordan
jordan.n.ray@Us.army.mil
bdboyle
Sep 16, 2019 05:58 PM
CaptainHam
Oct 1, 2015 01:38 AM
Rocky15
Sep 28, 2015 04:59 PM
pino
Sep 26, 2015 08:05 PM
jessejamestw23
Sep 26, 2015 03:57 PM
