2006 S-type High Beam RHS not working,
Old Dec 4, 2013 | 02:35 PM
skotchybaby's Avatar
Red face 2006 S-type High Beam RHS not working,
fuse-bulb-power all good, What's wrong?
LHS all good and beam works
I am at a loss.
TIA for help
Ken
Old Dec 4, 2013 | 02:42 PM
jimbov8's Avatar
Hi Ken,
If you have power up to the ballast then your problem will most likely be that.
If not, check the relay and fuse supplying it.
Hope this helps,
Old Dec 4, 2013 | 05:12 PM
I am at a loss.
TIA for help
Ken
Welcome to the forum Ken,
I've moved your question from Jaguar Forums Advice / Feedback & Suggestion Center to S-Type forum. Members here with the same model will be able to help.
The Jaguar Forums Advice / Feedback & Suggestion Center is for posts about the forum and NOT for tech questions.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Dec 4, 2013 | 05:23 PM
tbird6's Avatar
If you don't want to buy any parts. Start swapping one part at a time to the other side. The high beams on all S Types are Halogen and not HID’s so no ballast.
How do you know that all those items are good?
I believe the headlight are on relays and not fuses. Because of safety reasons. If you get a short then the relay will cycle the lights off and on so you have a chance of getting home. If they had fuses you would be dead in the water.
Old Dec 4, 2013 | 06:18 PM
Six Rotors's Avatar
Check continuity of the ground wire at the head lamp connector when the headlamp switch is in the on position--
The headlamp ground comes from the FEM(front electronic module).
The circuit for the lamp is activated by this unit switching the ground supply when headlamp switch turned on.
If you truly have power on the power wire at the headlamp connector then there must be a fault in the grounding circuit, eg broken ground wire or faulty FEM.Since the other head lamp works it is unlikely to be the head lamp switch.
All the circuit information you need is in the Electrical diagrams given in the JTIS.
(Ask me how I know----in my case there was a broken power wire between the fuse block and the head lamp connector,I decided to figure it out myself when the shops gave me a $900 estimate to fix. )
stanjag
Dec 29, 2024 08:26 PM
1100me
Aug 27, 2020 11:37 PM
johnnie ryall
Oct 19, 2015 09:44 PM
johanasu
Sep 3, 2015 12:39 PM
kesslari
Aug 31, 2015 04:53 AM
