2006 S Type V6 brake issue
Old Apr 17, 2021 | 01:52 AM
Jymkym1's Avatar
Default 2006 S Type V6 brake issue
About a month ago I had the brake pedal go soft, nothing leaking so I filled the reservoir and it worked fine. Now today the brake pedal has gone soft again, checked brake fluid, no leaking, the only light I have is the traction control.
Old Apr 17, 2021 | 08:42 AM
S-Type Owner's Avatar
Perhaps the master cylinder is leaking out the rear seal and into the brake booster...?
Old Apr 17, 2021 | 09:22 AM
Jymkym1's Avatar
The reservoir didn't appear very low. And since it happened before and started working again I didn't think it was the master cylinder
Old Apr 20, 2021 | 09:50 AM
Aarcuda's Avatar
how soft? Soft typically means air in the line. Being a little low wont make it soft unless its really low and you start sucking air. Air will compress when the master cylinder tries to pump uncompressible brake fluid
A bad piston seal in the master cylinder can also make it feel soft as fluid spits around the seal as you apply the brakes
SamtheSham
Feb 15, 2019 10:01 AM
XJSHouston
Dec 12, 2018 01:59 AM
davchr
Nov 13, 2017 11:16 AM
mark1210
Nov 1, 2017 11:41 PM
