3.0 intake elbow...
Old Apr 20, 2011 | 05:27 PM
SchultzLD's Avatar
Default 3.0 intake elbow...
I'm working on custom fabbing a intake elbow for my 3.0 but before I move forward I have a few questions that someone may be able to answer for me. I'm a Airframe Engineer, can build about anything out of Composites or Metals, but need some help with flow dynamics.
The 3.0 has a 2.5 inch TB with a 3 inch MAF. My question is what would be better, a 3inch intake reduced to 2.5 inch just before the TB thus increasing velocity but disrupting the flow, or a 2.5 inch intake with consistent flow? This would mean the intake would be reduced just after the MAF possibly disrupting the readings?
Any help would be GREATLY appreciated. Thanks to all in advance.
Lucas
Old Apr 21, 2011 | 03:14 PM
SchultzLD's Avatar
Any input welcome, the more the better. If you have any ideas at all I'd like to hear them. I'd like to make some sort of an educated guess before I start fabbing something up. I'd like to start this weekend, so... BUMP.
Old Apr 26, 2011 | 06:29 AM
SchultzLD's Avatar
O.K. well I guess thier is no inputs or opinions so I'm going with the 3"intake reduced to 2.5" at the TB. I just don't want any reversion on the MAF if I reduce it there.
I'm going to include pictures of the build as I progress if any of you are interested this will be EASILY reproduced as a DYI with some basic tools.
Old Apr 28, 2011 | 02:21 PM
cammerfe's Avatar
Sorry I just noticed this. I believe you're making this far too complicated. For example, for reversion to be in play, you'd find it necessary to have such air speed that you'd have to be traveling at several times the speed limit.
You can find lots of info on this subject if you go to the LVC forum and look in the sections focused on the Lincoln LS.
KS
Old May 2, 2011 | 05:28 AM
direng's Avatar
I am not familiar with the layout of the pipework on this model?
To keep turbulence and therefore resistance to a minimum I would go for the longest taper I could from 3" to 2.5" over the straightest part of the tubing that I could find and keep a fixed diameter within 5" from any bends.
If you have a scaled line drawing of the plumbing I would be happy to give you my 2c.
For a 3 litre engine @ 3000rpm consider an airflow of 75 l/s through the tubes.
Eddie.
Old May 2, 2011 | 06:27 AM
SchultzLD's Avatar
Outstanding info. Thanks.
cammerfe thank you for the advise but I greatly disagree about reversion. I'm a aivid Rider and that is a huge issue with bikes sometimes even at idle.
Anyways, I've already fishished the build, physically anyways, still got the cosmitcs to worry about. But over all I'm very happy with it. Noticble throttle responce improvment, and after a few more miles I'll do some math on MPG. I didn't do this for the negligable HP gains, more for economics.
https://www.jaguarforums.com/forum/j...ictures-53929/
xjrjag
Oct 12, 2015 03:16 PM
Newark Nj Gang
Oct 2, 2015 02:39 PM
Johncy2000
Oct 2, 2015 01:05 AM
Roman fellow
Sep 26, 2015 10:19 AM
