Another LED swap post
Old Jun 4, 2009 | 06:03 PM
Bull27's Avatar
I ordered them from www.superbrightleds.com , the ones for the front have 5 LEDS and are "cool white". I havent gotten the shipment yet that has bulbs for my interior and license plate as well. I think they were only $3-$4 each, so its probably not worth returning them, I'll just find another place to put em.
Unfortunately i dont have foglights, i guess the STR's 2005 up dont have them because that is were the intake for the supercharger is or some sh*t. Your lighting set up must look SWEET.
Basically I am just looking for something to match the HID's, and from what I am reading color in the 4000-4500K is where I want to be.
Old Jun 4, 2009 | 08:43 PM
JOsworth's Avatar
yea, ducts for the intercooler. So, you only have rear fog lights.... The color your talking about sounds about right. I don't have the HID's so I'm running the Silver Stars. Thanks for the site, I'll check them out.
Old Jun 8, 2009 | 03:42 PM
Bull27's Avatar
Got the bulbs today, installed them, look AWESOME. Highly recommended. Will try to take pics in low light.
Of course there was a small snag. After taking the left license plate bulb out, and replacing it with the new LED i noticed it didnt work. The right one did, left one did not. It was working before i took out the original so i dont know what the heck happened. I tried to put original back in just to see if it worked but to no avail. Any ideas?
Old Jun 8, 2009 | 04:32 PM
JOsworth's Avatar
Try to switch the bulbs. I thought I goofed mine up the first time I did it. It ended up that when I switched the way I put the bulb in, it worked. The other thing would be to check the connections. Do you have a tester?
Old Jun 8, 2009 | 04:36 PM
phd12volt's Avatar
mine are bright as hell in the license plate section. They are so bright, they light the ground up under the rear bumper. Mine are from superbrightleds.com also, i use their stuff alot.
Old Jun 8, 2009 | 04:42 PM
Bull27's Avatar
Ya unfortunately I did try and flop the bulbs around but still nothing. I am thinking I might have done something to the wires/connection, those suckers are tough to pull out! Its not like I was tugging on the whole unit, just the bulb. I dont have a tester, maybe should see if one of my buddies has one, I know a couple electricians.
Josworth, did you ever take a look at the site and/or get anything? Personally I think the front side bulbs look the best, perfect color.
Old Jun 8, 2009 | 06:11 PM
JOsworth's Avatar
Not yet. Plan on it soon. So you decided to put the LED's in the front parking lamps? The 5 LED units fit ok?
Old Jun 9, 2009 | 12:37 PM
  #28
Bull27's Avatar
Here are some pics, I know they kinda suck, tough to get lighting to show up the way they look in person. They look ALOT brighter.
Old Jun 9, 2009 | 01:11 PM
JOsworth's Avatar
Those look cool. I'm gonna get the ones you are using for the parking lamps! I see you fixed the license plate lamps. What was it?
Old Jun 9, 2009 | 01:44 PM
  #30
Bull27's Avatar
Ha, good work noticing that...Well I didnt have time to look into it yesterday, and it magically came on when I put my headlights on today. The Jaguar gods were nice to me today.
Just an FYI for anyone that is thinking of switching out their parking lamps. I have read on some posts to just pull them out, and they will come out if you pull hard enough. Not sure that is the case, at least on mine it wasn't. Thank god I read the manual because you actually have to turn the white, plastic clip casing counter clockwise then pull them out. On mine they were NOT just stuck in there, they were locked in with this plastic "casing" thing, if you will.
Old Jun 13, 2009 | 11:38 AM
  #31
03JagSTR's Avatar
Very nice LEDs. Now you just need to get a set of the chrome turn signal bulbs for the front. They look clear when off, but flash amber when you use the turn signals. I did the same for my rear turn signals. No more amber glow either front or rear.
Here is a site where I purchased mine........
http://www.xenonmods.com/xenonmods_c...bulbs_main.htm
FrickenJag
Jun 16, 2025 02:15 PM
Rivguy
Dec 4, 2020 07:55 AM
1LowCat
Sep 14, 2015 07:51 PM
sklimii
Sep 5, 2015 06:04 AM
bdboyle
Sep 4, 2015 06:16 AM
