Anyone see this on the Eaton forum?
Old Jul 19, 2010 | 06:40 PM
Mafioso's Avatar
Default Anyone see this on the Eaton forum?
http://www.eatoninside.com/showthread.php?t=1327 Killer Chiller exposed.
Old Jul 19, 2010 | 07:47 PM
Staatsof's Avatar
What you're looking at there is just an oil-to-water oil cooler. They've been around for a while. I just put one on my race car because I didn't have room for a big enough air-to-oil unit which is what most vehicles have. I don't think anyone has patent rights to those units.
I haven't looked that closely at the killer chiller because I basically don't believe in the design. It will heat-up after long runs so it's only good for bursts at best. That's just fine for many folks needs. It also may have very different coolant flow charcteristics than a simpler air-to-water unit. So a direct copy no.
Bob S.
Old Jul 20, 2010 | 10:09 AM
Mafioso's Avatar
why would it only work for a short burst? if the freon is keeping the plates cool.
Old Jul 20, 2010 | 11:35 AM
qwiketz's Avatar
there's guys that road race with the unit with decent results
Old Jul 20, 2010 | 12:10 PM
avos's Avatar
What has been uncovered is the plate type heat exchanger killerchiller is using. This one you can buy for about $79 (instead the $750 from kincaid, where you buy the idea and some connectors/tubes...).
Here is where you can buy the heat exhanger, and then you can make your own:
http://www.dudadiesel.com/choose_item.php?id=HX1230ST
Old Jul 20, 2010 | 12:35 PM
Mafioso's Avatar
Here is the place I source my fittings and hoses for EVERYTHING from:
http://www.stuarthose.com/
kevinl
Oct 31, 2019 06:15 PM
