Brakes losing vacuum
Old Feb 16, 2022 | 01:49 AM
bizz3's Avatar
Default Brakes losing vacuum
When engine is at running temperature bakes initially work for a second, then pedal goes hard as if there is no vacum or power assist.seems to be ok when car is cold.has anyone any ideas please, as at present my mechanic is scratching his head, so im hoping to assist him in diagnosing problem.any help greatly appreciated🙂
Old Feb 16, 2022 | 06:38 AM
Sportston's Avatar
Originally Posted by bizz3
When engine is at running temperature bakes initially work for a second, then pedal goes hard as if there is no vacuum or power assist.seems to be ok when car is cold.
Could be a vacuum leak. Check all vacuum pipes and joints for leaks by spraying Easy Start around them when the engine is running. Be thorough. If the engine note changes, you have found a leak.
The other possibility is a leak inside the servo, in which case it would need reconditioning or replacing. One way to check this is to pump the brake rapidly while the engine is running. If the engine goes to die, you have a fault in the servo. If the engine note changes only slightly it could be ok.
Try the above tests and please report back results for analysis.
Old Feb 16, 2022 | 09:52 AM
elDariusVargas's Avatar
do a smoke test to easily find any openings in the intake system
Old Feb 17, 2022 | 07:38 PM
davidladewig's Avatar
The check valve on your brake power booster is shot. Same problem here but O'Reilly's has it. It is a pain to get it out, but it is small and hooked to a vacuum line. You will have to look at the choices to the right one. It is less than $10.
Old Feb 20, 2022 | 12:59 PM
Joedotcom's Avatar
hi
if it a diesel, then your servo failed
very common on diesel, non return fails and oil gets into the servo and the diaphragm fails
if its petrol then could be a split in the vacuum pipe, or again servo
cheers
Joe
Sid's XF
Nov 5, 2014 05:03 PM
lickahotskillet
Jan 3, 2014 03:53 PM
Jag Po'
Jul 26, 2010 07:58 AM
inertian
Jun 4, 2009 09:04 PM
