A/C Problem - compressor not working
Old Jul 9, 2020 | 11:11 AM
clubairth1's Avatar
Community Influencer
If the clutch coil is your problem you only need to replace the AC clutch.
You can replace the entire AC compressor and if the car has a lot of miles you might be ahead to just replace the entire unit.
Old Jul 27, 2020 | 09:52 AM
dennysjag's Avatar
Default coil
simple test for clutch coil using an ohm meter. between pins or if single pin then pin to ground should read between 3 and 5 ohms
Doug
Mar 30, 2017 12:10 PM
Hustle Hyde
Sep 30, 2016 12:34 PM
Thia
Jun 20, 2016 04:53 PM
supra-raleigh
XJ40 ( XJ81 )
Oct 15, 2014 09:32 PM
