compression testing
Old Mar 26, 2011 | 07:21 PM
achysklic's Avatar
Default compression testing
After seeing a recent thread on a spark plug change. I suggested the OP do a compression test.
This got me thinking, yes I am very ****, what are the compression ranges for the 4.2?
I have a tester and think I will run it tomorrow,(I might as well since I will be replacing the coils while I am at it) just want to know the normal ranges to expect.
Old Mar 26, 2011 | 11:06 PM
Bamaman's Avatar
Does your car have normal oil consumption? Is it running okay? Have you pulled the spark plugs and inspected the color of the electrodes?
The spark plugs tell a tale if you'll just read them.
With any aluminum head, I don't want to change any plugs or screw anything into the spark plug holes unless absolutely necessary. Aluminum heads are just too easy to crossthread. (I speak from experience.)
Old Mar 27, 2011 | 04:41 AM
achysklic's Avatar
My plugs are fine, however right before I received my car the previous owner had new plugs installed so I have no idea what the old ones looked like.
It uses no oil, but I would like to know now if any potential problem may arise.
I have no worries about alum. heads I have ran compression test on them many times I will be extra careful though, Thanks
Arlo
XK120 XK140 XK150
Nov 1, 2015 05:44 PM
carl purchase
Oct 14, 2015 06:14 PM
leep123
Sep 30, 2015 03:41 PM
reb1999
Sep 26, 2015 08:41 AM
Jaguar Forums Editor
Jaguar Press release
Sep 25, 2015 11:58 AM
