DCCV replacement - From top or bottom
Old Oct 31, 2017 | 12:08 PM
ashmorem's Avatar
Default DCCV replacement - From top or bottom
About to replace a suspect faulty a DCCV in my 2006 V6.
Wondering which is easiest way to access and replace? From above or remove the under-shield and complete from the bottom? Have researched quite a few posts but seems there is not really any preference on this? Welcome suggestions.
Old Oct 31, 2017 | 12:13 PM
kr98664's Avatar
On my '02 V6, I did it from above. Not sure about any differences on the later models.
Gus has a good writeup of the process on an early model:
JagRepair.com - Jaguar Repair Information Resource
If the late version is similar, make sure you follow his suggestion to notch the mounting flange on the new DCCV. It makes installation a LOT easier.
Old Oct 31, 2017 | 12:47 PM
aholbro1's Avatar
03 and subsequent facelift models are reportedly easier. I've done it more times than I care to count on the 03/05 and prefer working from both above and below, with front wheels on ramps.
Rick prefers working all from above. It's doer's-choice IMHO. I recommend underneath for you, OP as your car is in the window age-wise for a radiator tank seal leak (I don't know your mileage, but they spring a leak about 100k-115k, from 9 yrs on) and it always leaks right in front of the DCCV and blows back on it....
Old Oct 31, 2017 | 12:53 PM
joycesjag's Avatar
On our 2005, V6, I went at it from above. Took twenty minutes from start to finish along with a cold one.
Old Oct 31, 2017 | 01:09 PM
Above for me also!
Old Oct 31, 2017 | 02:33 PM
Jon89's Avatar
I would choose the reverse cowgirl positio............ whoops, wrong forum.... Sorry....
Old Oct 31, 2017 | 02:36 PM
NBCat's Avatar
I have always removed and replaced them from above with the radiator fan assembly removed for more space.
Old Nov 1, 2017 | 12:28 AM
Datsports's Avatar
crikey !! thats a lot of extra work ,
for me it was also from above with a cold one . radiator and fan still mounted . as stated under 30 mins. mine has the v8 auxiliary coolant pump in the way also . still easy enough . the v6 should be a breeze.
Old Nov 1, 2017 | 07:17 AM
aholbro1's Avatar
Dammit Jon! I was drinking coffee!
Old Nov 1, 2017 | 07:20 AM
Jon89's Avatar
Sorry, Zane. Hope you have a spare clean shirt with you....
Old Nov 1, 2017 | 08:22 AM
joycesjag's Avatar
Still laughing after 5 minutes!!!! Good one Jon!
Old Nov 1, 2017 | 08:28 AM
NBCat's Avatar
Originally Posted by Datsports
crikey !! thats a lot of extra work...
It takes me about ten minutes to remove the radiator fan shroud, but then there is plenty of space to work and I have not had a problem with the DCCV mounting bracket that way.
Whichever way works best for you is the method to use.
