Differential leaking oil
Old Mar 19, 2017 | 05:30 PM
flatlander's Avatar
Question Differential leaking oil
My new long wanted S-Type was purchased just about a week ago but I am going thru some struggles with it just failing an annual inspection.
There are a number of things to be fixed and the leak of the differential is one of them.
I was thinking that could I simply apply an "stop leak" product and call it a day?
They are made to at least stop some leak, maybe only small ones though, but the cost difference between the stop leak application VS garage charge are tremendously big that I am hoping that there is a hope for use of such chemicals.
Has anyone heard of it being useful for such leak around differential part(s)?
If so where do I add the chemical? Do I add to the transmission box?
Best,
Old Mar 19, 2017 | 05:35 PM
JBzXJ40's Avatar
Depends on what part of the differential its leaking from, might just need a new seal which are inexpensive, and not a major to do. Do you have any pictures of the leak?
Old Mar 19, 2017 | 05:38 PM
flatlander's Avatar
Unfortunately not. But it appears that the leak is caused from the long pipe that goes into the differential and not actual differential.
Old Mar 19, 2017 | 05:41 PM
flatlander's Avatar
Is this job a DIY worthy?? I have been changing control arms and suspension kits. And that's as much as I can DIY but anything related to transmission/oil sound/look little too advanced.
Old Mar 19, 2017 | 10:12 PM
JBzXJ40's Avatar
do you mean the driveshaft?
Old Mar 20, 2017 | 10:18 AM
clubairth1's Avatar
Community Influencer
For a rear end leak the only solution is to repair it. There are no wonder stop leak products in a can that will do anything for you.
Have you checked the level?
I think you are talking about the oil coming out the vent?
This is hard to see and is on the right side on top of the pumpkin.
Just a note? On my 2005 STR I changed the rear end fluid and got a small seep afterwards. Never did find where it was coming from but it looked like the vent.
I opened the fill plug and took a bit more fluid out and have had no seeps since then. I must have slightly over filled it.
