Differential Output Seal
Old Apr 13, 2021 | 11:28 AM
2003WHTSTR's Avatar
Default Differential Output Seal
Hi! I'm replacing the rear tie rods and upper wishbones on my 2003 STR. I have a driver's side differential leak on the output shaft.
I've done a search on this topic and read all I found, but still have a couple of questions:
  • Will I be able to remove the half shaft from the diff as I have the suspension apart? Or do I need to go through the whole procedure outlined in the workshop manual?
  • Do the half shaft retaining clips need to be replaced? If so, where to source?
  • And lastly, source for the output seal?
Thank you for your time
Old Apr 16, 2021 | 04:22 PM
2003WHTSTR's Avatar
I got the new seal in.
When putting the half shaft back in, The manual say use Loctite. Anybody know what type? Loctite 620?
the groove
Mar 30, 2015 09:24 PM
jakeperigo
Jul 29, 2014 06:11 PM
okStypeR
Apr 15, 2013 09:55 AM
penguin
Mar 18, 2013 12:10 PM
zmann96
Aug 28, 2011 06:32 PM
