Error code one after another
Old Mar 22, 2025 | 02:03 PM
Charlies's Avatar
Default Error code one after another
Ok. So from my previous topic about weird car sound that developed we found out that my radiator was allrady repaired by someone and it started to leak. I met up with the guy in thursday with someone who is a member of Jaguar club here in Slovenia. We plugged in the tester to the car and we found that cars engine was changed because it shows different VIN number as well we found following codes.P0102 - I assume it is connected with P010F
P010F - Checked the Mass Air Flow filter, unplugged it while running engine, the engine did not turn off so MAF is not working
P0331 - Something connected with knock sensor?
P0299 - Connected with turbos, maybe also culprit to restricted performance?
P0625 - Something connected with car's alternator?
B1318 - Battery. Maybe low voltage or maybe bad alternator?
P0402 - I guess it is connected to P140D and restricted performance
P140D - I guess this is cause of restricted performance because of EGR valve
P0706 - Something connected with gearbox? Also noticed that black gearbox cover in tha cabin is running hot
B2291 - Connected to airbag sensor on passenger side
The car is S-type executive 2004 2.7D.
Old Mar 22, 2025 | 04:46 PM
scrannel's Avatar
Battery first, you must be sure it's charged.
EscapedApe
Mar 10, 2026 10:24 AM
Arbroaths55
UK & Eire
Mar 9, 2020 12:50 PM
kreyszig
Mar 18, 2014 12:28 PM
boosoo
Jun 12, 2011 11:41 AM
burmaz
Nov 23, 2010 03:39 AM
