Front Brakes
Old Sep 14, 2011 | 11:42 AM
cagsjag's Avatar
Default Front Brakes
I have some terrible squeaking coming from the front brakes.... does anyone have any experience with the duralast gold brake pads from autozone??
Old Sep 15, 2011 | 07:36 AM
joycesjag's Avatar
I have them on the wifes. There is no noise from them, they work well. The only complaint I have is that they cause more brake dust from other brands of ceramics that I have used.
Old Sep 16, 2011 | 02:19 PM
Amadauss's Avatar
Same thing here Rick, they seem great and no squeaking but I do have to clean the wheels from the dust that accumulates.
Old Sep 16, 2011 | 06:36 PM
ndy4eva's Avatar
i have duralast gold on front and back. it does make more dust than oem but it does work quite well no squealing.
Old Sep 17, 2011 | 06:59 AM
The Chris X's Avatar
I have them on my Jeep. Perform pretty well considering the rotating mass of 33" tires and I often have a trailer in tow. Dusty mess, but I don't really care on that vehicle. Pretty good pads for the money.
Old Sep 18, 2011 | 01:28 PM
matty427's Avatar
This is what I think I understand about brake materials and problems. Anyone please feel free to correct any gaps or misunderstandings on my part.
Brake squeel can be caused by several issues but it is only a high frequency vibration. This was a major problem for automobile mfg.'s when they were obliged to switch from asbestos composit material in the 80's to something else. Customers would continually complain and request warranty service concerning squeeky brakes.
The solution was to use very soft pad compounds that lasted about half the mileage of previous material. Thankfully, the newer materials of the last few years are much improved and last longer, but harder pads can sometimes cause squeel.
For example race brake pads operate at very high temperatures and are extremely hard, and they most often squeel like hell.
Special hi-temperature grease applied to the rear and contact surfaces of the pad can help eliminate or lessen the squeel.
We used to insert a shim at one end of the rear surface of the pad so that it would attack the rotor at a very slight angle and thus eliminate the vibration (squeel)
I hope any of this is a help, constant brake noise can be a real PITA.
Old Sep 19, 2011 | 07:36 AM
The Duralast brakes are definitely soft enough that squealing isn't an issue - some have a built in backing pad on the individual pads that also helps. Still have to use a brake grease on the backing to keep the noise down on any pad. I buy the larger squeeze bottle of red CRC brake pad lubricant since I do all my own brake work.
clubairth1
30
Sep 3, 2025 04:38 PM
H20boy
Dec 24, 2024 03:23 PM
mbergen
Oct 23, 2019 10:26 PM
PMKimpton
Aug 3, 2019 08:22 PM
KarimPA
Sep 12, 2015 08:15 AM
