Fuel door broken-is there a hack?
Old Dec 13, 2025 | 11:57 PM
mikesbaron's Avatar
Default Fuel door broken-is there a hack?
2005 S-Type R.
The end of the tab on the fuel door broke and has been lost. Is there a cheap or easy way to fix it so it will at least stay closed?
Old Dec 15, 2025 | 10:51 AM
Docmonte's Avatar
Do you have a photo?
I had a similar problem but I am not sure if yours is the same. I will share my post with you
Old Dec 15, 2025 | 10:53 AM
Docmonte's Avatar
https://www.jaguarforums.com/forum/s...m_content=post
Old Dec 15, 2025 | 10:55 AM
Docmonte's Avatar
Look at post #6 and #7. I have photos of my situation. If yours is similar, I did a quick fix hack to keep the door closed without replacing any parts and it took about 10 seconds
Old Dec 15, 2025 | 11:54 AM
mikesbaron's Avatar
Yes looks like same problem. The end of the tab that clicks into the fuel assembly lock is broken, therefore it won't lock or close all of the way.
Old Dec 15, 2025 | 02:38 PM
Docmonte's Avatar
The gold coloured metal clip that accepts the tab is designed to flex a little bit and spread when the fuel door is pushed in and then closes around the tab. The quick and cost free fix is to bend the gold clip, widen the gap, so that the door will close. It will not lock in place any longer but it will close and open freely. You will not need to use the remote fuel door button in the car any longer. It will just manually open and close. That is what I did and it works perfectly fine.
Old Dec 15, 2025 | 05:40 PM
scrannel's Avatar
Disc Magnet...
Old Dec 15, 2025 | 08:41 PM
mikesbaron's Avatar
I saw your thread but I don't understand the "fix" for it.
Old Dec 15, 2025 | 08:53 PM
mikesbaron's Avatar
Ok at a closer look at mine, the tab isn't broken. So I will try bending the metal tabs a tad. I would like to see the "disc magnet" setup though. Can you explain or post pics?
Old Dec 17, 2025 | 08:17 AM
scrannel's Avatar
The magnet idea came from an earlier thread dealing with the same issue. Here's one way...
But if there's room you can just attach a thin magnet to a metal place on your gas area that the door will also contact when closed.
Old Dec 18, 2025 | 11:24 AM
mikesbaron's Avatar
Nice, great find. Thanks.
vandenplas90
XJ40 ( XJ81 )
Oct 23, 2021 06:48 PM
SDCR_XK
Jul 13, 2021 07:32 PM
honghanbyul
Apr 19, 2017 06:08 AM
happy
Jul 2, 2016 06:54 AM
