Fuel pressure
Old Nov 13, 2017 | 05:36 PM
scuba's Avatar
Post Fuel pressure
does anyone know the correct fuel rail pressure at idle and wot ? On a 2002 s type with 3.0 engine
Old Nov 13, 2017 | 09:48 PM
abonano's Avatar
Idle: at least 40 psi (ideally closer to 45+psi) anything under 40 psi after turning ignition on (before engine start) is a red flag!
Not a 3.0 expert but I know I'm in the ball park.
Old Nov 14, 2017 | 07:00 AM
clubairth1's Avatar
Community Influencer
Remember there is no static fuel pressure reading because it's based on intake pressure/vacuum. So at idle it will be about 40 psi and when you rev the engine it will jump around.
Do you have a problem or just checking fuel pressure?
