FUEL tank seals - vendor source
Old Aug 19, 2020 | 02:50 PM
jaimster's Avatar
Default FUEL tank seals - vendor source
I thought i would share where i ordered my fuel tank seals both of them 207.00 total from www.checkeredflag.com , drivers side ( sending unit ) was leaking real bad also I decided to DO the pump side .. both of them are held secure by a large metal clamp each which are still in pretty good shape . I had previously spoken top Dealer about the issue . they wanted almost 200 to inspect them ! so much for that ..
just in case somebody is shopping around for the INFAMOUS SEALS..
Old Aug 19, 2020 | 03:47 PM
wydopnthrtl's Avatar
FYI.. the fuel pump I used came with it.
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
I might still have the original laying around. If I find it I'll measure it and update this post
Old Aug 20, 2020 | 12:15 PM
S-Type Owner's Avatar
Jaimster, are you referring to the two seals at the access points for the fuel pump and sender on the top of the tank? If so:
Amazon Amazon
Old Aug 20, 2020 | 01:00 PM
kr98664's Avatar
Originally Posted by S-Type Owner
are you referring to the two seals...
Another source:
https://tinyurl.com/yxqx5gv2
Those are common seals.
Old Aug 20, 2020 | 01:02 PM
I knew that I should have called the parts "gaskets"...
Old Aug 20, 2020 | 02:29 PM
jaimster's Avatar
hehe.. they are actually
Fuel Tank Sending / pump Unit Lock Ring man . they are expensive
Part Number: XR850737
bullittandy
Jul 27, 2015 04:58 PM
Bc xj
Jun 21, 2014 05:37 AM
bhamilton
May 18, 2014 04:55 AM
Calhale
Nov 20, 2012 07:45 AM
Jag_Generation
Apr 29, 2012 12:10 PM
