head gasket! maybe or cooling !
Old Dec 10, 2016 | 03:01 PM
  #61
Ducmon's Avatar
Can you get hold of a bottle of blue-metal-marking-layout-ink ?
put a thin layer on a sheet of glass and move the clean cylinder heads on the glass sheet move the head around. turn around head and look to see if any Areas do not have ink on it. If so heads are warped.
to check the pistols pins are all right go to this thread it shows what to do on a youtube vid
https://www.jaguarforums.com/forum/s-type-s-type-r-supercharged-v8-x200-15/engine-knocking-sound-2001-jaguar-s-type-173459/#post1581168
Old Dec 10, 2016 | 03:46 PM
  #62
jaimster's Avatar
yea Ducmon .. I can try to get those things from home depot or wallmart the ink.. I will take a picture of the other side of the heads forgot to do that ..
I just watched the video.. how ever I'm not sure if its a good idea to turn the crankshaft with out the timing chains on ! without the heads no cams on ! what do you think?
and I also have a straight edge and gauge that I was going to use to check on the heads warp condition ??
Old Dec 11, 2016 | 03:07 PM
  #63
Ducmon's Avatar
Did the head gasket s show any signs where they had failed?
the way with the glass is a method that I have used before to test heads, it is a lot easier to do than using a straight edge and a gauge.
it also takes about a minute to check each head that way.
how are the chains?
Old Dec 11, 2016 | 03:33 PM
  #64
jaimster's Avatar
the chains look good .. I think ! I will clean everything tomorrow and post couple of photos .. I had a hard time releasing tension on both tensioner so I just ended up removing the bolts to get tension off .. I didn't know how to release the tension I DO NOW... I hope I can still use same tensioners
the head gaskets ! looks like some of silicon had was coming off as when I was loosing the cylinder bolts I found: the passenger side -- I found the back cylinder bolts were not TIGHT AT ALL... loose on driver side too..
not as bad when you compare how the other were they were pretty tight..
just remember I have a bottle of black printer ink is it possible to use that ink ??
Old Dec 11, 2016 | 03:59 PM
  #65
Ducmon's Avatar
I don't think that printer ink will work because it is not designed to work with metal.
but you can make your own
https://en.m.wikipedia.org/wiki/Engineer%27s_blue.
very strange that the bolts were loose was there any signs that somebody had been there before you because it sounds like someone had not torgued the heads up correctly.
Old Dec 11, 2016 | 06:58 PM
  #66
jaimster's Avatar
no signs ! that somebody had messed with it before .. no way to know for sure ..
wallmart sells the stuff I will just order it from them may take few days to get it thought .
anyways I'm still waiting for gasket kit from rock auto,, as far as testing the piston I watched the video . I'm hesitant on turning the crankshaft with out the chains!!
I did pushed on the pistons felt NO Movement at all !
here is an idea : how about if I mark the crankshaft keyway position , them turn the crankshaft one full turn checking pistons as I turning it clockwise NOT COUNTER . definetly would like to verify pistons are ok IF possible like on the video.
do you think I wont get into trouble doing that ?
also I did have loosen the oil pan to get cover off do you think I can get away using same oil pan gasket ? was thinking about putting a bead of gasket silicon around pan before tighten down the pan again..
Old Dec 12, 2016 | 12:17 PM
  #67
joesoap's Avatar
The most important part is setting up the variable cams, be careful take your time and follow the instructions to the letter.
Did the heads on my xj3.0l last year got it running it was pretty straight forward but I am a industrial maintenance engineer: but its not for the faint hearted!!
Old Dec 12, 2016 | 02:43 PM
  #68
jaimster's Avatar
I m also looking for suggestions:
what to use or how to clean matting surfaces on heads and block to get the gasket material off and thoroughly clean surfaces ..
I saw a youtube video using 3m roloc bristle white disc ! wonder if somebody has used that method before..
gracias..
Old Dec 12, 2016 | 03:41 PM
  #69
Ducmon's Avatar
I personally would use an aerosol gasket remover such as https://www.permatex.com/product-category/gasketing/gasket-removers/ with the safe scrapper.
this would mean that you less chance of damage the surfaces.
Old Dec 12, 2016 | 04:27 PM
  #70
joesoap's Avatar
I used a brand new stanley blade and was very careful, for heavy stuff used a piece of stiff plastic.
Old Dec 12, 2016 | 06:41 PM
  #71
jaimster's Avatar
I saw a video on youtube from rockauto it looks like thorough cleaning of surfaces ..
I did order the the 120 grit disc and holder .
its the only they recommend using on aluminum .. well see how it works
Old Dec 13, 2016 | 04:35 AM
  #72
joesoap's Avatar
some recommend replacing knock sensor while in that area?
Old Dec 13, 2016 | 08:51 AM
  #73
jaimster's Avatar
yes I tought about getting a new one . I will order a new one .. so far I'm getting
head gasket kit
new spark plugs
new coils
thermostat NOT water pump it looks fine !
and knock sensor
Old Dec 13, 2016 | 10:37 AM
  #74
Ducmon's Avatar
Have you cleaned the barrels yet? If not do it and spray some oil in them to stop any rust.
Don't forget to get a new oil pan gasket as you had to loosen the oil pan. it's not worth the risk of using the old one after you have done all this hard work and invested all the time and money.
its looking good just take your time and keep checking the manual.
Old Dec 13, 2016 | 06:13 PM
  #75
jaimster's Avatar
oh yea ! I almost forgot I will get a oil pan gasket too.. do I have to lift the engine to replace it ? I will look at the FSM and I will spray some oil on barrels too
..I will have to get back on the project till next week ,, this week I'm doing a home project ceiling texture on family room and kitchen .. removed old pop corn on / off project few months now .. decided to get it done finally ..
gracias ..
