Heat disappear
Old Nov 1, 2011 | 02:30 PM
jagspeed's Avatar
Default Heat disappear
I change my thermostat because the heat i was getting was very low. However i changed it and its hot but when the car is moving the heat disappear and all the cold air from the outside come through vents. Any help is appreciated.
Old Nov 1, 2011 | 03:24 PM
uropnm6's Avatar
Make sure you bleed the cooling system correctly. Sounds like air trapped
Old Nov 1, 2011 | 03:52 PM
jagspeed's Avatar
What is the suggested way to bleed the system. I ran the system on hi and remove the coolant cap.
Old Nov 1, 2011 | 04:22 PM
tot's Avatar
tot
Maybe a dumb question, but have you rechecked the coolant level? After using the car the level might still drop and if too low, no heat.
Old Nov 1, 2011 | 05:05 PM
jagspeed's Avatar
Not dumb question and it was the first thing I check before changing the thermostat
aode06
Jul 28, 2023 02:26 PM
Delta66
Oct 4, 2015 05:40 PM
Newark Nj Gang
Oct 2, 2015 02:39 PM
inactualis
Oct 2, 2015 11:13 AM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
