Help With ABS 2002 S-Type
Old Mar 25, 2012 | 12:09 PM
NapoKomplex's Avatar
Default Help With ABS 2002 S-Type
Good Afternoon -
I have an issue with my 2002 S-type ABS system. I recently got some front end work done Upper Control Arms, Lower Ball Joints, Tie Rods, Sway Bars. Uppon replacing all these parts, I began to drive and the Car started to doing a grinding sound when I would press on the brakes. Mechanic checked brakes (not an issue they are new pads), nothing was in between rotor and brakes. He then told me i would need to replace wheel hubs. I replaced the wheel hubs and the problem did not go away. He did a quick dianostic by disconnecting the ABS sensor on passenger side of wheel well. To surprise the grinding stops, but of course my ABS, and Traction control lights comes on my dash. I would really like to handle this issue because driving around with ABS unplugged is not safe. Please recommend what I should do. This was not an issue before he worked on the front end. I'm tired of spending money and not fixing the problem. I was told that maybe a computer issue, and that the battery must be disconnected before discu=onnecting the sensors, not sure. If a computer problem how do i get the computer reset
Please any help would be greatly appreciated... napokomplexmedia@gmail.com
2002 S-TYPE 3.0... 83K Mi..... Cleveland, Oh
bdboyle
Sep 16, 2019 05:58 PM
Dave1109971
Sep 30, 2015 11:04 PM
jessejamestw23
Sep 26, 2015 03:57 PM
zdrapec
Sep 25, 2015 05:49 AM
