I think I solved my lean bank 1 & 2 problem - RESOLVED
Old Nov 4, 2019 | 08:39 PM
  #41
scottjh9's Avatar
Absolutely fantastic. I plan on doing an upper pulley mod myself just the first stage though. I did get a nice tip from avos about the intake pipe going into the throttle body to use one off a Land Rover and it will increase flow through the whole intake system I am looking into that right now.if you want to check out the thread it is titled intake mod by AlexJag about modifying the air filter in the x 150 forum I believe
Old Nov 4, 2019 | 11:34 PM
  #42
Aarcuda's Avatar
Originally Posted by Brutal
That brake booster line where it goes into the tb elbow is the number one cause of vacuum leaks on lean engines by far. The egr port is right by it so it gets nice hot exhuast to cook the o ring and lock ring for that tube. I have several different new tb elbows i need to get on ebay and am in the middle of cleaning out my collection of new and used parts in my shop. I usually put 3m silicone paste on this pipe to easy entry and help provide a little better sealing
I tapped mine and put a hose on it to get rid of the oring
Old Nov 4, 2019 | 11:38 PM
  #43
Aarcuda's Avatar
I used the caldoofy air intake. Love it!
Old Nov 5, 2019 | 06:29 PM
  #44
scottjh9's Avatar
the one i am talking about is the intake scoop from the caldoofy pipe to throttle body.... apparently it is larger internally and has a better angle into the throttle body for increased air flow
Old Nov 8, 2019 | 07:20 PM
  #45
Aarcuda's Avatar
Oh I didnt know about this. I will check it out. So it fits and all?
Old Nov 8, 2019 | 07:34 PM
  #46
scottjh9's Avatar
Check out the 2ñd or 3rd page of a thread on the x150 forum by alexjag titled intake air filter retrofit....avos linked a picture of it.....and has answered my question about it
Old Nov 8, 2019 | 07:38 PM
  #47
Aarcuda's Avatar
Btw I noticed many of my flanges werent flat. Typically if the part of the flange had a hole for the bolt and the area was narrow or unsupported like the corners, I found the flange warped and the bolt areas higher than the rest of the sealing surface. I carefully sanded them flat with 400 or 800 grit on a super flat sanding surface trying to be as flat and even as possible. These intake egr and throttle body gaskets seal by slightly Slightly crushing a raised mound around the port its sealing. I found my gasket had flattened areas and a lot of misalignments which cut down on air flow, and caused slight leaks.
also I semi ported (gasket matched) a few surfaces like the throttle body to elbow (big lip in there but now as big and smooth as the gast opening. Also around the intake ports. It could use a good head porting bc it leaves a lot of metal there and each dual port is one big and one small port separated by a thin divider. That could be ported really nice IF the head was off. But im not going there.
heres some pics
You can see the edges are high after a few swipes on the EGR tube
Other end of egr tube is just as bad
After finishing its flat
You can see the big lip in this before pic
Hers the elbow with an old gasket showing how much meat is in the way
This too got some filing
Old Nov 8, 2019 | 07:48 PM
  #48
Aarcuda's Avatar
More
Its much better. All matched. Be careful when installing the gaskets and take time to center the gasket on the bolt holes or else the gasket sticks into the opening and the sealing bump on the gasket makes the edge of the gasket kind of flare up and not seal well
Wide open
More flattening and slight porting
These ports look cracked to me. I can see a line down the center divider and in the edges aligned with the bolt holes. Do you see it? I sanded these surfaces on the intake but not the head due to debris
Looks cracked to me
More crackalacka
My blower might need repair. I saw some section of smooth shiney vane edge. 😬
Think I flattened this. I know I did the other piece
Got a new radiator cover. Mine was missing. I had to cut out this section to clear the overflow tank.
Old Nov 8, 2019 | 07:53 PM
  #49
Aarcuda's Avatar
More
Ported elbow with vacuum fitting tapped in place. Ended up changing the fitting to a different style for better clearsnce
Flaking rotor coating. I wish this were all it was
More. Worst is to come
Not sure how bad this is but ive always been told this should never look like this
Final rad cover mods
And back together
Old Dec 12, 2024 | 01:58 AM
  #50
Superdad's Avatar
Default halloween fogger
Did you make a smoker or buy one.....i want one myself, but know zip about them..thanks
just buy a fogger for 25.00 us it works great
Chuck Schexnayder
Dec 21, 2016 11:10 AM
Vektor75
Feb 26, 2016 03:28 AM
Complic8d
Dec 11, 2015 12:02 AM
bfsgross
24
Dec 30, 2011 10:33 AM
Cerberus
Dec 7, 2008 09:39 PM
