Jaguar S type 2005 3.0 V6 Tempreture gauge cluster
Old Apr 7, 2025 | 11:13 AM
Nassify's Avatar
Lightbulb Jaguar S type 2005 3.0 V6 Tempreture gauge cluster
Hi There,
I am looking for a help and have a question about the Jaguar S-Type 3.0 V6: When doing a cold start and turning the ignition to the second position (without starting the engine), the temperature gauge immediately moves to the middle, as if the engine is already at operating temperature. After I start the engine, the needle slowly drops and then gradually rises again as the engine warms up. Is it normal for the gauge to show normal operating temperature during a cold start, even though the engine is still cold? or i shoult have problem with the cluster needle. hier is the Link to the video on Youtube to see what i mean.
The OBD2 tempreture is allreday checked and it works how it should be working. that means the coolant tempreture sensor and the ECU should be working correktly i think so.
.I will be happy to get some helpfull information.
Thank you in advance.
Old Apr 8, 2025 | 11:07 AM
clubairth1's Avatar
Community Influencer
I "think" what your seeing is the problem with Jaguar temperature gauges?
We don't really have a gauge it's an "indicator" and the needle has purposely been damped to stay in the middle of the scale for a wide range of actual temperatures. This is a fact and has been documented on this forum a number of years ago.
The theory is that Jaguar had way too may warranty claims because owners would see the gauge move as it's suppose to with different operating conditions. Get "concerned" and bring it in when nothing was wrong with the car. This is just a guess however.
You can read many peoples problems and they all say the gauge did not move to the over heat position until it was too late.
You are wise to monitor what's really going on and I use Torque Pro to read what the actual engine temperature is.
So yes it's operating as designed it's just a poor and not a well thought out design decision by Jaguar.
Old Apr 8, 2025 | 01:40 PM
sov211's Avatar
When the engine is started (cold) the gauge initially reads at its position when the engine was last shut off. The needle then moves toward the cold end to start a new reading. Perfectly normal for the S-Type gauge (mine does exactly the same slow dance); but it is a bit disconcerting when you first notice this behaviour.
Old Apr 9, 2025 | 01:22 PM
Nassify's Avatar
Thank you for your comment. I think everything should be normal with the display and the temperature, and from what I've read through research, that's normal for Jaguars. And as you said, perhaps this isn't well thought out by the Jaguar manufacturer. Or maybe it's good thinking.
Old Apr 9, 2025 | 01:25 PM
Nassify's Avatar
I'm now reassured, especially after measuring the temperature with the OBD2. It showed the correct reading. 17-95 cilisus paralell with needle job.
Old Apr 25, 2025 | 08:36 AM
clubairth1's Avatar
Yes that's the only way to get the correct coolant temperature. I also do this with Torque Pro.
mhamilton
Sep 18, 2024 09:03 PM
jamdmyers
Jun 18, 2024 10:31 AM
Robert Rodriguez
May 19, 2021 03:22 PM
Zulu4me
Oct 3, 2017 06:55 AM
Maninahat98
Sep 22, 2013 06:07 AM
