Hi all,
I'm trying to find the location of the Camshaft Position Sensor for my Jaguar S-Type 3ltr v6 2001.
I have got the new one and have been searching a lot on this site and the web. Could someone point me in the right direction?
thanks bigalan
thanks bigalan
close
- Join DateDec 2011
- LocationDurham, UK
Liked:17,008 Times in 12,222 Posts
Here's the sensor locations for your S-Type:
The CPS is item 3.
The CPS is item 3.
JimC64
close
- Join DateNov 2006
- LocationGlasgow, Scotland UK
Liked:9,029 Times in 4,120 Posts
Homerun in one..............nice one Graham.
Sorted BigAl?
thanks ggg for the very fast reply.
this is whot i got when read the car with my pc (p0341 camshaft position sensor "A" circuit range performace) so orded 2x camshaft sensors hoping this will sort the problem was geting confussed with these and the crankshaft sensors will have look at car agen with the digram you have selplied and hope i can sort it thanks agen
joycesjag
close
- Join DateFeb 2009
- LocationSunny South Carolina
Liked:1,731 Times in 1,223 Posts
I knew I had some pics of the camshaft sensors (CMP)
close
- Join DateDec 2011
I often find a drawing of what the sensor looks like is as much, if not more help than where it's located.
The full description of possible causes for P0341 on the 2001 S-Type is:
Bank 2 CMP Sensor disconnected
Bank 2 CMP Sensor gap incorrect / foreign matter on sensor face
Bank 2 CMP Sensor sensing circuit: open circuit, short circuit to ground, short circuit to high voltage
Bank 2 CMP Sensor reference ground circuit (to splice) open circuit
Bank 2 CMP Sensor failure
Although sensor failure is the likely cause, don't discount cleaning required or bad harness connections before splashing the cash.
thank you both that makes it a lot clere so think the sensors i got are the crankshaft sensors and not the cam shaft sensors i orded have atched a pic of the one thay have sent me this is probly why i cudent see them do these twist rater then un bolt like the one on the pic i posted
