lower steering shaft telescoping ?
Old Mar 21, 2026 | 08:41 AM
pdr1966's Avatar
Default lower steering shaft telescoping ?
Changing rack, and having trouble extending the lower steering shaft to get the joint fully seated on the pinion of the rack.....
Am I missing something? Suggestions?
In past experience other cars, I would expect the shaft to extend/retract with relative ease??
2003 S Type R 4.2L SC
Old Mar 21, 2026 | 10:12 AM
clubairth1's Avatar
Community Influencer
Your in Canada. Any chance it's rusted up from the road salt?
Old Mar 21, 2026 | 10:50 AM
pdr1966's Avatar
Good chance, but it doesn't look bad up there - asking to see what "normal" should be like.
And yes LOTS of rust in the rockers!
Old Mar 21, 2026 | 11:32 AM
scottjh9's Avatar
I had that union apart on my 06 str last year and i had to use force to separate and even with clean up as best i could i still had to tap it strongly to reattach. It is in an akward spot that does not help. I was able to get it started then use the now free hand to hold it in a good position. Hope this helps some. Oh yeah. Make sure the splines are exactly aligned using the keeper bolt slot as reference. I was one spline off for a bit and had your same troubles
Old Mar 21, 2026 | 07:55 PM
pdr1966's Avatar
have oriented correctly and started now, but definitely needs to go on further - I think such that the pinch bolt passes through the cut in the pinion.
Old Mar 22, 2026 | 05:22 AM
Sportston's Avatar
Is the pinch bolt removed?
Jagboi64
Dec 11, 2025 01:30 AM
AZDoug
Apr 23, 2025 01:43 AM
Hoffe
May 16, 2024 01:02 PM
MrAndersonGCC
Jun 7, 2022 12:19 PM
Mad Hatter
Dec 11, 2021 11:05 AM
