MAP sensor?
Old Apr 26, 2017 | 05:24 AM
pappy's Avatar
Default MAP sensor?
Hi all,
​​​​​I own 2005 S type 4.2,
That​​​​​​ hose blew under the intake.
Now​​​​​​ that I have the intake off should I replace the MAP sensor or just clean it? Also are the bent arnley good parts?
Old Apr 26, 2017 | 11:35 AM
DaimlerMK2's Avatar
MAP?
Old Apr 26, 2017 | 12:38 PM
clubairth1's Avatar
Community Influencer
I would not replace anything unless it's throwing a code.
MAP sensors and not a known failure item so you should be pretty safe.
Old Apr 26, 2017 | 03:55 PM
pappy's Avatar
Default clubairth1
Pappy's jaguar has 80000 miles on it and that MAP sensor is under the back of the intake. I think while it is apart it would make sense to make sure everything is going to last as long as possible.
