Navigation Migration
Old Apr 28, 2016 | 11:00 PM
Glennemo's Avatar
Default Navigation Migration
Hello all. I just picked up a 2007 S-type 3.0 to replace my 2004 x-type 3.0. The X has navigation and a Parrot mki9000 and the S-type does not. I figured I would swap the radio's and climate controls of the two cars thinking that the connections would all be the same and the s had the wire bundle in the boot for DVD install. All was going well until I saw that the S has 2 connectors for the climate control (dual zone I figure) and the x nav system only has 1. I figured no big deal I'll loose 1 side of the climate control. But, neither of the connectors fit into the connector. Is there a workaround or a harness that I'm missing? Is the the nav system in the x different than the s? All the screw holes on the cages lined up perfectly so I'm thinking they use the same unit. And I will also need the workaround when I go to put the climate and stereo in the x.
