need help please
Old Mar 3, 2010 | 05:05 PM
Leedsman's Avatar
If your battery has been replaced without maintaining the +12volt to the radio (by clipping a small batt. to the connectors during change) the radio will have lost it's operating code; the display will say something like "insert code". You will have to find the code and tap it in to the keypad, then it should burst into life. If it doesn't say anything in the display, then it's poss. blownfuse etc.
Re. the whistling noise, one of the mechanics on this site may know, but you may have to furnish more info., e.g. where exactly is the noise coming from? Engine area, gearbox area, somewhere else?
Leedsman.
Old Mar 9, 2010 | 12:10 PM
jjag's Avatar
Default what kinda whistling noise
if the whistling noise gets higher when you rev the engine its most likely a bad ground conection
