New daily means big STR plans
Old Mar 22, 2012 | 09:07 AM
qikcat's Avatar
Default New daily means big STR plans
I have been holding out on taking the Jag down since I really didn't want to daily drive my beater trailblazer. I decide to pull the trigger and get a decent daily so I can go over board on the STR!
Picked up a new GL550 loaded out. 0-60 in 5.9 and the thing will spin all four 21" 295/40/21s all the way through first LOL! Its a beast for what it is and a lot of fun to drive. A pic with it and the jag (its pollen season here in the south and everthing is coated with a yellow haze)
Now the STR is getting pulled down, I am putting the aggressive ported SC on it (I will have mine for sale soon), direct porting the NOS and reworking the alky inj. Adding a new heat exchanger and rear mounted tank to allow for icing at the track and lots of extra volume for cooling on the street, killer chiller and custom long tubes if they get the price where I want it. I am looking into heads and cams but already looks like for the small gains on FI motor it is not going to be worth it cost to power ratio wise. We are talking over doing the LSD swap and just milling the LSD/Housing to make it work, jury is still out until we pull the rear and see how it will look dimensionally but I have a quaif on order now with the understanding if its to much work or wont fit I can return it.
I will make a post with pics and information as we get started. I am next in line for the lift as soon as my shop gets another project finished up in the next two weeks.
Old Mar 22, 2012 | 10:00 AM
Michael Star's Avatar
Mafiaoso said he got the xkr unit to fit with some machining on the lsd...
Old Mar 22, 2012 | 10:36 AM
bfsgross's Avatar
Nice daily beater (MB 550S). Not meaning to peek into yer pocketbook, but did ya happen to inherit some dough my favorite uncle; qwikcat? Isn't the present STR blower ported? If yes, interested in some dough plus my present blower?
Old Mar 22, 2012 | 10:52 AM
qikcat's Avatar
Thats what I am hopping. I ordered the unit for a jag and hope it wont be to bad to mill it down
Old Mar 22, 2012 | 11:00 AM
qikcat's Avatar
Originally Posted by bfsgross
Nice daily beater (MB 550S). Not meaning to peek into yer pocketbook, but did ya happen to be inherit some dough uncle qwikcat? Isn't the present STR blower ported? If yes, interested in some dough plus my present blower?
Nah just final decided to put more effort into my real work and less to playing with race cars so its paying off. I build clean rooms for biotech, pharmaceutical company's, nano technology etc... So I normally build one a year and play with race cars the rest of the time but now that I am actually going out and selling I am doing four + rooms a year.
My blower on the car now is stock with a milled snout for the 3# pulley. I could get my guy to port it out to once its off, rebuild it like my new one and it would be a quick swap out like what I am doing.
Old Mar 22, 2012 | 03:48 PM
qwiketz's Avatar
Shoot, if you're doing this much work, I'd find a way to get a whipped or kenne bell on there. You'll really be able to have some fun then!
Old Mar 22, 2012 | 06:36 PM
bfsgross's Avatar
Sure, ya got a clean room I can build?
Old Mar 23, 2012 | 05:58 AM
qikcat's Avatar
That was discussed. I had already made plans for the ported 112 and have no idea where the ecu will step in or we run out of pump or inj and since its all wired together that would mean doing a standalone. I am not adverse to doing a standalone but it kinda takes the easy bolt on aspect out of it.
Absolutely! You bring me a client that needs one and we will work something out
Old Mar 23, 2012 | 06:19 AM
Nice, Im so jealous...
Old Mar 23, 2012 | 07:33 AM
Bacardi 151's Avatar
For all the money you're apparently going spend...Why not fab up a custom sheet metal intake S/C delete and add a big turbo? I'm sure you already know you don't need to place the turbo under the hood, it can be placed inside the rear bumper...
Old Mar 23, 2012 | 10:27 AM
qikcat's Avatar
I am not a big fan of rear mounted turbos personally but we did have the turbo discussion. Since turbos are what I do and am most accustom to it makes sense. I am with you on the that's the way to go with a no holes bared project.
Problem is again the ECU and fuel since if I went that far I would be shooting for 650+ rwhp. To do it right with turbos or turbo to more exact I would double the cost not including a standalone ecu and quadriple yes that's quadriple! the unknown factor and the my car is never going to be done factor. I have done that many times and don't want to go down that path again. What I have planned is mostly bolt on with a touch of fab and a pinch of hope I don't outrun the ecu.
This project wont be to expensive believe it or not. Swaping blowers isn't that bad and I have next to nothing in the spare and porting, the nos system was comped so that is nothing but labor, I bought the killer chiller a while back and I will fab the rear tank myslef.
Lsd, headers and heat exchanger is where I am spending my money. of course it always cost more then you had though
Old Mar 23, 2012 | 11:13 AM
FYI: Avos TWS setup is about 650hp and he claims the ecu and fuel are fine...But yeah, I understand there could be several unknown factors...
Old Mar 23, 2012 | 11:26 AM
That is why we are all going to watch qikcat's build We will all learn a lot I think.
Old Mar 23, 2012 | 11:52 AM
qikcat's Avatar
I am going with a lower pulley as well if the blower looks to be keeping the heat down. I should be moving more CFM at the same boost just as I have it. If I can keep the heat down I would like to push it to 18-19# of boost since that's about where the 112s seam to run out of efficiency even ported on the other platforms.
It will no question be a learning experience if theory holds hold true in reality. Avos and his information is one of the reasons I know how to approach this. The ECU is so invasive that its meant throwing a lot of common wisdom out the window until I say screw it and pitch the ECU.... which I hope not to do since it appears I may be able to push the limits of it and still get there.
Old Mar 23, 2012 | 10:08 PM
qikcat's Avatar
Anyone know what's the best 1/4 mile time for an STR?
Hope to get a few good runs with this setup before she goes under the knife so I can use track data as well as dynos to see how well the improvements work.
Old Mar 23, 2012 | 11:18 PM
rasputin's Avatar
you are the winner according to dragtimes.com (upload your time). i am looking forward to your build and shared successes. thanks!
Old Mar 24, 2012 | 07:52 AM
qikcat's Avatar
Someone has had to go faster then that? It's pretty anti climatic if I already hold the title. Oh well I am shooting for 11s anyway this trip out guess that will be my goal.
clubairth1
30
Sep 3, 2025 04:38 PM
Dimitrigregorio
17
Sep 5, 2019 03:47 AM
Daim
Nov 28, 2016 09:28 AM
handcuffsready
Sep 7, 2015 03:16 AM
XFR_Gold
Sep 2, 2015 12:24 PM
